Username Post: Electronic Ignition        (Topic#355572)
jeff198901
Reg: 09-16-17
03-11-19 11:57 AM - Post#2761840
I am looking at the PerTronix electronic ignition that goes in the distributor cap. Does anyone have a link to the kit I should use for a 427 BBC?
What wires do you recommend?
Also, how do I tell if my car already has an electronic ignition kit installed?
Thanks!
Jeff
Edited by jeff198901 on 03-11-19 12:01 PM. Reason for edit: No reason given.
Lead sled
Lead sled
Loc: Walton,NY.
Reg: 11-04-09
03-11-19 12:02 PM - Post#2761841
    In response to jeff198901
I ordered mine from jegs.com
Late yr model (Dec. 51 BelAir/ 52 trim), with a basically stock 67 Camaro SS350/295hp Turbo Fire Edelbrock 1405, Saginaw 4spd/355 geared 55/6 Chevy rear.2,1st place,and 1 top five award trophies so far
toro455
toro455
Loc: Western NY
Reg: 06-15-02
03-11-19 03:43 PM - Post#2761861
I installed one which I bought from Summit Racing. I don't recall the difference but there were 2 PNs which were nearly identical at the time for the same application. The difference I think had to do with how parts of the kit were mounted. When I phoned Summit even needed to dig deeper... Too long ago to recall the specific difference unfortunately but I do recall I was glad I found out what the difference was before buying. I also recall I did need to shim the distributor to get the clearance the instructions wanted to see.
Scott
Oshawa65SS
Loc: Burnaby BC Canada
Reg: 09-22-14
03-11-19 09:55 PM - Post#2761900
I have the Breakerless SE and it's a great upgrade.
Single wire hookup so it looks 100% stock and it's easy to install.
Just have to file down the rotor a bit underneath as per the instructions.
Super forgiving with no shiming or gaps to set or concerns about distributors that are showing their age and getting a little sloppy.
Ryan
65 Impala SS convertible 283 2V with Powerglide and 10 bolt 3.08 open
Build date Dec. 21 '64 Oshawa
Texasray
Texasray
Reg: 11-01-16
03-12-19 03:39 AM - Post#2761903
    In response to Oshawa65SS
Jeff, first to your Question "how do I tell if my car already have electronic ignition installed"
Pop the distributor cap off and check for points and condenser. Check images online if you are not sure what they look like. If you don't have experience with distributors you may want to pay someone to install it for you.
I installed my #1181 on our '72 vette back in about 2000 when we bought it. Easy to install, good system and no problems since. The 1181 comes with a ring that bolts under the rotor & the control replaces the points & condenser set up. I did shim my distributor to remove some of the play from the years of wear but the timing is rock steady. I also replaced the stock coil with the Pertronix coil in 2002.
Now on the Impala, in 2015 I bought a aftermarket dist and control box that cost way too much. I can't use a typical timing light with it. I thought since I was building a serious street motor I needed it. I have found no difference in the function or output of the two systems. Just the expensive system is harder to modify the advance, and it wants you to buy their timing light.
Live & learn I guess. Anyway I have been using the 1181 for 18 years now and if you didn't know to look for two wires coming out of the dist cap you wouldn't know it wasn't stock. I do like not having to replace points every year or so.
Good luck, Sam
66cayne
Reg: 08-06-08
03-12-19 07:02 AM - Post#2761916
It does not sound like you are familiar with distributors. Do you know if you have a stock type or HEI distributor installed? If it is a stock type, remove the cap and see if it has a set of points installed. If no points then it has been converted to electronic. One advantage of the Pertronics system is you will not need to remove the distributor to install it. Get the Pertronics II or III kit.
jeff198901
Reg: 09-16-17
03-14-19 08:02 AM - Post#2762057
    In response to 66cayne
I noticed two wires coming out the bottom of the distributor. One black and one red wire. I assume this is the electronic ignition
jeff198901
Reg: 09-16-17
03-14-19 08:11 AM - Post#2762058
https://www.flickr.com/photos/159670980@N02/ 473780...
Oshawa65SS
Reg: 09-22-14
03-14-19 10:33 PM - Post#2762109
Looks like you're already setup with a Pertronix with the red and black wires coming out, although you've got a later distributor with the numbers on the body.
Original year distributor would have the numbers on a metal band wrapped around the bottom stem of the distributor.
Stock 65 distributors or Breakerless SE conversions are single wire.
Look under the cap to see just what it is though, or post a pic of the numbers and the cap view of the distributor.
Ryan
Execution time: 0.088 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:41 PM
