Username Post: Edelbrock 1406 stuck throttle        (Topic#355555)
57 Al
Loc: Minden, LA
Reg: 02-02-14
03-10-19 08:17 AM - Post#2761715
After parking my car for about a week, I tried to start it and the throttle linkage is stuck like it's in a bind.
03-10-19 09:23 AM - Post#2761725
    In response to 57 Al
Welcome!
The rear motor mounts may have broken, causing the rear of the engine to drop down and put the linkage in a bind. Link to linkage.
57 Al
Loc: Minden, LA
Reg: 02-02-14
03-10-19 03:38 PM - Post#2761759
    In response to acardon
Motor mounts o.k. Everything worked fine last time I drove it. I've started it up a few times since then . But yesterday I tried to start it and throttle was stuck. Un hooked it from petal, still stuck. Unkooked acceldrator pump, still stuck. Any ideas?
steve65
steve65
Loc: new westminster bc
Reg: 09-25-13
03-11-19 10:35 AM - Post#2761833
Have you tried shooting penetrating oil on/in the butterfly valve shaft(s)? With all the linkage disconnected, it seems like the only other place to seize.
Steve
Steve Duncan
65 Impala SS Convertible
Ermine White/ Black Top
357 4 spd auto
www.picturetrail.com/steved65
57 Al
Loc: Minden, LA
Reg: 02-02-14
03-13-19 03:07 PM - Post#2762011
    In response to steve65
Thanks, I'm gonna take it off and try to figure it out. I put a spacer under it awhile back. Coulx be binding on it. Will report back.
57 Al
Loc: Minden, LA
Reg: 02-02-14
03-24-19 07:38 PM - Post#2762800
T V cable was stuck. Greased it up good. Everything fine now.
Execution time: 0.076 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:24 AM
