Username Post: Edelbrock 1406 stuck throttle        (Topic#355555)
57 Al
Loc: Minden, LA
Reg: 02-02-14
03-10-19 08:17 AM - Post#2761715
After parking my car for about a week, I tried to start it and the throttle linkage is stuck like it's in a bind.
03-10-19 09:23 AM - Post#2761725
    In response to 57 Al
Welcome!
The rear motor mounts may have broken, causing the rear of the engine to drop down and put the linkage in a bind. Link to linkage.
57 Al
Loc: Minden, LA
Reg: 02-02-14
03-10-19 03:38 PM - Post#2761759
    In response to acardon
Motor mounts o.k. Everything worked fine last time I drove it. I've started it up a few times since then . But yesterday I tried to start it and throttle was stuck. Un hooked it from petal, still stuck. Unkooked acceldrator pump, still stuck. Any ideas?
steve65
steve65
Loc: New Westminster BC
Reg: 09-25-13
03-11-19 10:35 AM - Post#2761833
Have you tried shooting penetrating oil on/in the butterfly valve shaft(s)? With all the linkage disconnected, it seems like the only other place to seize.
Steve
Steve Duncan
66 Impala 2dr Coupe
Not sure of color yet
work in progress
57 Al
Loc: Minden, LA
Reg: 02-02-14
03-13-19 03:07 PM - Post#2762011
    In response to steve65
Thanks, I'm gonna take it off and try to figure it out. I put a spacer under it awhile back. Coulx be binding on it. Will report back.
57 Al
Loc: Minden, LA
Reg: 02-02-14
03-24-19 07:38 PM - Post#2762800
T V cable was stuck. Greased it up good. Everything fine now.
Execution time: 0.121 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:36 AM
