Username Post: 65 Chevy c10        (Topic#355540)
aarow
Reg: 02-02-19
03-09-19 10:31 AM - Post#2761649
65 truck won't start after running for a while again any tips
Chevy_Stepside
Chevy_Stepside
Loc: San Francisco, Ca, USA
Reg: 07-08-02
03-09-19 11:54 AM - Post#2761652
    In response to aarow
Can you give more info. What kind of ignition are you running? If it is electronic it could be the module. When they get hot they stop working but will again when cooled off. How old is the fuel filter? could have crap stuck in it and it is being starved for fuel. Easy way to check is to take it off and try blowing through it without tasting gas (yuk). If there is resistance I would start with that.
"A man and his truck, It's a beautiful thing"
The tour is on again. May 1st 2011. $5 I ride 100 miles. http://main.diabetes.org/site/TR?pg=personal&a mp;f...
aarow
Reg: 02-02-19
03-11-19 01:54 AM - Post#2761805
    In response to Chevy_Stepside
Hei.on 350 eng. 5.7 4bar.Holley also checking for heat soaked wiring around headers could I upgrade to a better quality module.increased my batt.c.c to 1000 as well thanks for info!
Chevy_Stepside
Chevy_Stepside
Reg: 07-08-02
03-11-19 08:19 AM - Post#2761825
It might just be the module. Mine was bad and my truck would just shut off like I turned the key off and I had a brand new dist. Modules are pretty inexpensive so it might be worth replacing
aarow
Reg: 02-02-19
03-11-19 09:01 PM - Post#2761897
Thanks,replacing it will see the outcome.
sidworks
Loc: Sidney, B.C.
Reg: 12-03-05
03-11-19 11:06 PM - Post#2761901
modules either work or they don't. if your truck does start when cold then the module is working
ron
http://www.sawmillcreek.org/showthread.php?208929-...
http://www.sawmillcreek.org/showthread.php?220902-...
http://forum.woodenboat.com/showthread.php?156542-...
aarow
Reg: 02-02-19
03-13-19 09:17 PM - Post#2762035
    In response to sidworks
Changing batt. To 1000 c/c ran it today for and hr. Came back home shut her down started again after a few clicks. Love these old truck. Thanks friend..
Execution time: 0.064 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:42 AM
