Username Post: Fuel Pressure Gauge        (Topic#355522)
apix17
Loc: San Francisco Area
Reg: 12-22-07
03-06-19 09:13 PM - Post#2761503
I would like to install a fuel pressure gauge in the engine compartment near the edlebrock 4 barrel on my 55 SB Belair. The smallest low pressure gauge I can find is inch and a half. It seems I have seen some smaller then that but have been unable to find one.Any help appreciated. Thanks.
5Larry7
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
03-06-19 09:22 PM - Post#2761505
    In response to apix17
Here's one I found on eBay:
https://www.ebay.com/itm/Gauge-Fuel-Pressu re-Gas-C...
apix17
Reg: 12-22-07
03-06-19 09:30 PM - Post#2761506
    In response to 5Larry7
Thanks Larry but I think that one is also considered inch and a half. The seller may not be including the frame around the face. Thanks for your input.
Mel Foye
*VIP* Founding Member
Mel Foye
Reg: 09-29-00
03-09-19 10:45 PM - Post#2761696
Not sure what your goal is. One time check of pressure why not use a quality vac gauge to check pressure. Usually pressure gauges go on pass side and you are working the throttle on drivers side --can you see it?
They can leak. My experience is where you lose pressure is winding out and idle readings don't tell the whole story.
On a road course car we run a remote gauge so we can read it through the ws. Good luck and have fun.
Execution time: 0.074 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:08 PM
