Username Post: 57 Bel Air horn cap removal, how?        (Topic#355490)
Beltfed
Reg: 10-04-18
03-04-19 04:20 PM - Post#2761306
I’m trying to remove steering wheel in an attempt to get the gauge/speedometer cluster out. I can’t get by first step of removing the horn cap. The manual says to ‘pry’ it off. Well, using two medium size pry bars and putting as much pressure as I dare, it won’t budge. Does it indeed ‘pry off’ or twist and turn, or a hidden fastener? Thanks.
03-04-19 04:27 PM - Post#2761307
    In response to Beltfed
There is a hole in each spoke with a clutch head screw (if they are original) holding the cap on.
Belair-o
Reg: 03-26-07
03-05-19 06:51 AM - Post#2761356
    In response to acardon
What Don said. You might try a mirror to see the screw heads, so you know what driver to use.
Regards, Doug
Beltfed
Reg: 10-04-18
03-06-19 10:41 AM - Post#2761451
Thanks guys. I found the two clutch head screws. Thank goodness you are more informed than the shop repair manual and the factory assembly manual. I’ve worked on a lot of different old cars (Packard, Studebakers, etc.). The information is sometimes somewhat sketchy but just flat wrong like these chevy manuals, never.
Execution time: 0.052 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:42 AM
