Username Post: Engine ID        (Topic#355430)
George56
Loc: Miami, Fl
Reg: 03-16-16
03-01-19 08:52 AM - Post#2761053
I have a Chevy engine and the block code is:
CE4N36101. Can anyone identify this number/engine ?
Thanks,
George
chevyman57B.C.
Reg: 08-29-12
03-01-19 10:32 AM - Post#2761054
    In response to George56
If you can get the cast numbers off the back on the drivers side or pull a valve cover and get the casting number there and the date.
Larry
Lead sled
Lead sled
Loc: Walton,NY.
Reg: 11-04-09
03-01-19 05:52 PM - Post#2761081
As near as I can tell it's a chevy crate engine hence the "CE". Here is a link. scroll down about 2/3rds down. best way to know, is to get the nums from above bell housing on left side.
http://www.chevy-camaro.com/chevy-camaro-engine-s u...
Late yr model (Dec. 51 BelAir/ 52 trim), with a basically stock 67 Camaro SS350/295hp Turbo Fire Edelbrock 1405, Saginaw 4spd/355 geared 55/6 Chevy rear.2,1st place,and 1 top five award trophies so far
Execution time: 0.058 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:17 AM
