Username Post: Mass Air Flow Sensor Problems        (Topic#355426)
wreakhavoc
Reg: 12-09-07
02-28-19 06:13 PM - Post#2761009
I have replaced my MAF sensor with a brand new one twice, clean used ones twice, and cleaned the wire sensors on my original one and no matter what I do the check engine light is still on and the codes are saying the MAF sensor is the culprit and it is running too rich.
What else can I do?
2000 Express 2500 van w/350.
Thanks.
454cid
Loc: West Michigan
Reg: 02-18-12
02-28-19 06:50 PM - Post#2761012
    In response to wreakhavoc
What else can I do?
Thanks.
What is the code? A code for something doesn't necessarily mean that part is bad. It can mean it's simply not reading what's expected.
99 K3500 RCLB
wreakhavoc
Reg: 12-09-07
03-01-19 05:57 PM - Post#2761082
    In response to 454cid
Exactly. Hence why I asked what else I can do to remedy this since replacing the sensor is not helping.
I do not have a code reader. I have taken it to two shops and Autozone to have it checked out and all have said the MAF sensor is not transmitting the proper reading and is causing the engine to run too lean.
454cid
Loc: West Michigan
Reg: 02-18-12
03-02-19 10:39 AM - Post#2761119
Get the codes pulled again, and ask for the specific codes.
99 K3500 RCLB
george88gta
george88gta
Loc: new york
Reg: 04-23-03
03-02-19 11:22 AM - Post#2761120
Definitely write down the codes. In your first post you say it is running rich and then, later on, you say it is running lean. The codes will help with the exact failure mode. If it is really running lean, do a thorough inspection of the air intake system, after the MAF, and up to the intake manifold. If you are comfortable with spraying carb cleaner around the joints, the engine rpm will increase if you spray a spot that is leaking. BE VERY CAREFUL, don't drench the engine with fluid!!!!! Codes are still the best way to diagnose this.
wreakhavoc
Reg: 12-09-07
03-02-19 05:26 PM - Post#2761135
    In response to george88gta
My mistake. I meant it was running too lean.
DenaliXL
Reg: 02-25-07
03-07-19 02:31 PM - Post#2761545
Perhaps the intake gaskets sucking unmetered air. Common with OEM gaskets.
elcamino
elcamino
Reg: 03-30-00
03-07-19 03:24 PM - Post#2761553
Are you using an oiled air filter?
Automatic Transmission Shift, Engine Driveability Concerns or Service Engine Soon (SES)
Light On as a Result of the Installation of an Aftermarket Reusable, Excessively Oiled Air Filter
Models: 2004 and All Prior Cars and Light Duty Trucks
2003-2004 HUMMER H2
DO THIS
First, Inspect the vehicle for a reusable aftermarket excessively oiled air filter
DON'T DO THIS
DO NOT repair under warranty if concerns result from the use of a reusable aftermarket oiled air filter.
The installation of an aftermarket reusable, oiled air filter may result in:
1. Service Engine Soon (SES) Light On
2. Transmission shift concerns, slipping and damaged clutch(es) or band(s)
3. Engine driveability concerns, poor acceleration from a stop, limited engine RPM range.
The oil that is used on these air filter elements may be transferred onto the Mass Air Flow (MAF) sensor causing contamination of the sensor. As a result, the Grams per Second (GPS) signal from the MAF may be low and any or all of the concerns listed above may occur.
When servicing a vehicle with any of these concerns, be sure to check for the presence of an aftermarket reusable, excessively oiled air filter. The MAF, GPS reading should be compared to a like vehicle with a OEM air box and filter under the same driving conditions to verify the concern.
Transmission or engine driveability concerns that are the result of the installation of an aftermarket reusable, excessively oiled air filter are not considered to be warrantable repair items.
2017 GMC Sierra Denali Ultimate 6.2L / 8-sp Z95
2018 Polaris RZR S 900 EPS
wreakhavoc
Reg: 12-09-07
05-29-19 07:46 AM - Post#2767279
    In response to elcamino
Sorry, forgot to update...
It turned out to be a combination of three things- mass air flow sensor was indeed faulty transmitting incorrect information to the computer, bad fuel pressure regulator, and a rivet was missing on the underside of the throttle body. All of this was contributing to running too lean, lack of power, and check engine light constantly being on.
To boot, one screw holding the distributor cap on was loose, apparently had been stripped for awhile, and caused a spark to fly out and start a small fire when checking the fuel pressure. Luckily the only damage was a couple of melted vacuum lines and the plastic conduit on one wire harness. Turns out the OEM distributor was plastic (unbelievable) where the distributor cap screws on so the rim around the little screw hole was broken off. We of course replaced it with an aftermarket metal distributor.
After months of frustration with this all is well. No more check engine light on and is running great and with the boost in power that a 350 should have.
Edited by wreakhavoc on 05-29-19 07:48 AM. Reason for edit: No reason given.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
05-30-19 06:56 PM - Post#2767375
Cant stress enough why I never understood the plastic distributor.
Every astrovan I ever touched had a broken distributor. I never replace the screws when I replace the cap. I think the threadlock stays in the threads and is too much when the new screws are installed.
Old School GM fan FOREVER
wreakhavoc
Reg: 12-09-07
05-30-19 07:13 PM - Post#2767377
    In response to rockfangd
Mine is Chevy Express 2500. My mechanic asked me if I had put in the new screws that came with the distributor cap. I didn't remember for certain but I said I probably would have.
When replacing a distributor cap in a van of course you're working from behind the engine so you can't really see what is going on with the front screw.
Execution time: 0.09 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:40 AM
