Username Post: Distributor wires installed a position off, need advice        (Topic#355362)
azjamtram
azjamtram
Loc: Phoenix, AZ
Reg: 02-23-19
02-23-19 05:29 PM - Post#2760580
My 1982 Chevy P 30 is a bread truck that I converted to a party bus. Year and a half ago I put in a new, or rather, rebuilt 350 which the seller was unsure of the year on but it’s either 82, 83 or 84.
A couple months ago I put in a new distributor and the guy who did it for me set the wires weird, but it works. From every diagram I have seen the number one wire should be pointed at the number one spark plug. My number one wire is pointing at the number seven piston. All of my wires are shifted to the left one position, but it’s running and it seems to be running OK.
I attempted to put the wires in the appropriate position and turn the distributor timing, and I wound up shooting flames out of my carburetor. Needless to say, the wires went back to being one position off.
Does anybody have insight on this as to why this set up is off one position and what I can do about it? Or should I just leave it the way it is?
From a rear view, you can see the number one wire points to 8 o'clock instead of 11 o'clock.
[image]https://img1.wsimg.com/isteam/ip/9e43f7b4-28 71-4ec8-a7cf-5f9ece3d38c5 /689deccf-d8c9-49f1-9d0d- 430097a149da.jpeg[/image]
https://img1.wsimg.com/isteam/ip/9e43f7b4-28 71-4ec...
A UNIQUE Party Bus for Your UNIQUE Party! JAM Tram!
Edited by azjamtram on 02-23-19 06:42 PM. Reason for edit: No reason given.
02-24-19 01:25 PM - Post#2760664
    In response to azjamtram
Doesn't make any difference where the wires are pointed, if the rotor is pointed to the number one cylinder/ wire when it is at tdc compression it is good to go after setting the timing of course.
azjamtram
azjamtram
Loc: Phoenix, AZ
Reg: 02-23-19
02-25-19 08:47 AM - Post#2760769
Ahhh. Ok, thank you, was getting really thrown off by my positioning compared to everyone else's. Mine didn't used to be off one, you'll see in the picture I had scratched in the during order, but this new guy helped put the wires when he put in the new distributor.
Thanks again!
Mercedes
Loc: Orlando Florida
Reg: 07-09-18
12-29-21 02:45 PM - Post#2833442
As mentioned by the prior contributor, which terminal you use as #1 is "almost" irrelevant as long as you follow the firing order. One thing that I have noticed on older Chevrolet engines is that the spark plug wires are a certain length based upon the factory position of the terminal.
Also, most HEI systems have the distributor sitting where the coil in the distributor is sitting straight across. When you do that, the vacuum advance unit is angled correctly. Use that arrangement to time your engine and you will be nearly perfect when you use a timing light.
Execution time: 0.59 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:32 PM
