Username Post: 3100 Door identification        (Topic#355300)
Dustythedog
Dustythedog
Loc: Niagara Falls NY
Reg: 08-10-08
02-18-19 11:43 AM - Post#2760206
I am restoring a 1953 3100 pickup basket case. It came with several doors. both seem to fit the truck but door handle holes are different. The best door has a larger hole and a smaller recessed hole. Other door smaller holes and no recessed hole. It seems like the ones with smaller holes are 47-50 and the larger hole is 51-54. Is this correct and 51-54 should not have a vent window? I'm just confused I think. Thanks.
Edited by Dustythedog on 02-18-19 11:50 AM. Reason for edit: No reason given.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
02-18-19 03:31 PM - Post#2760228
    In response to Dustythedog
The 1947-1950 has a conventional door handle and no vent window.
The 1951 has a conventional door handle and has a vent window.
The 1952 and up has a vent window and push button door handle.
02-18-19 08:39 PM - Post#2760260
    In response to Gene_Schneider
The push button door handle doors will have two holes to mount the handle and the twist style door handle doors have only one hole for the handle to pass through.
1957 Cameo Carrier
Dustythedog
Dustythedog
Reg: 08-10-08
02-20-19 08:55 AM - Post#2760348
Thanks, this helps a lot.
Dustythedog
Dustythedog
Reg: 08-10-08
02-20-19 08:57 AM - Post#2760349
    In response to wagonman100
Thanks. Very helpful.
Dustythedog
Dustythedog
Reg: 08-10-08
02-20-19 01:06 PM - Post#2760366
unclebrad
unclebrad
Reg: 03-12-19
04-17-19 05:25 PM - Post#2764425
I'm not sure whether I should be starting another discussion but I think my question has to do with another aspect of 3100 door identification, so...
My two doors (on a '55 2nd series truck) have different sized door panel screws. Meaning that the screws used to attach the door panels to the drivers' door have larger heads (and threads) than the screws used to attach the door panel to the passenger door.
The captive nuts don't look like they have been drilled and tapped, but I guess it is a possibility.
Anyone aware of this difference?
Anyone know which is correct for '55?
"55 Cameo w/409
Bel Air kiwi
DECEASED
Bel Air kiwi
Reg: 04-24-14
04-17-19 06:00 PM - Post#2764431
    In response to unclebrad
Hi Unclebrad, this sounds like you have doors from two different assembly plants or some PO has changed it.
Go to the forum index and search for the online service manuals. A very generous guy has given his time to compile these original documents and make them available.
Cheers Kiwi
Execution time: 0.144 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:25 PM
