Username Post: Help        (Topic#355291)
hunter67wa
Loc: Wyoming
Reg: 02-07-19
02-18-19 09:53 AM - Post#2760189
Ok I have a 66 K10 and on the front frame horns are two controllers I guess they are called that are riveted to the frame with a bolt coming down through them with rubber washers. These are broke and I have been looking for replacements to no avail. Any help would be appreciated.
Thank you,
fpd
Chevy_Stepside
Chevy_Stepside
Loc: San Francisco, Ca, USA
Reg: 07-08-02
02-18-19 06:11 PM - Post#2760244
    In response to hunter67wa
You will have to find some used ones. I think the part you are talking about is where the radiator support bolts up to. You could also get them welded up.
"A man and his truck, It's a beautiful thing"
The tour is on again. May 1st 2011. $5 I ride 100 miles. http://main.diabetes.org/site/TR?pg=personal&a mp;f...
hunter67wa
Loc: Wyoming
Reg: 02-07-19
02-19-19 02:02 PM - Post#2760306
    In response to Chevy_Stepside
Actually i dont think it is radiator support. If you look into the wheel well you can see them on outside of frame and it looks like front fender and grill frame go into them
Chevy_Stepside
Chevy_Stepside
Reg: 07-08-02
02-19-19 11:39 PM - Post#2760340
Are you talking about the supports that are in this picture. The radiator support bolts up to them.
hunter67wa
Loc: Wyoming
Reg: 02-07-19
02-20-19 06:41 AM - Post#2760342
By god yes. I see now how they work. Does anyone sell them? Will later models work for a 66.
Thank you so much!
Frank
hunter67wa
Loc: Wyoming
Reg: 02-07-19
02-20-19 10:50 AM - Post#2760356
I ordered some from LMC today for a 67
sidworks
Loc: Sidney, B.C.
Reg: 12-03-05
02-20-19 03:12 PM - Post#2760372
They may not be the same as for 1 the height may not be the same, think the frame horns are perhaps different and the rad mounting is different and that may change things. Different front sheet metal and that also may be a factor
Ron
http://www.sawmillcreek.org/showthread.php?208929-...
http://www.sawmillcreek.org/showthread.php?220902-...
http://forum.woodenboat.com/showthread.php?156542-...
hunter67wa
Loc: Wyoming
Reg: 02-07-19
02-21-19 07:51 AM - Post#2760407
    In response to sidworks
I agree but I hope we can fab them to make them work.
Chevy_Stepside
Chevy_Stepside
Reg: 07-08-02
02-24-19 07:56 AM - Post#2760628
Do you not have any wrecking yards near you? See if there are any 60-66 trucks. This is probably your best bet and I think I mentioned before you can get the old ones welded up maybe.
hunter67wa
Loc: Wyoming
Reg: 02-07-19
02-27-19 06:41 AM - Post#2760921
Wrecking yards are few and far in between here in Wyoming. I will see if the ones I ordered work. If not I will look on ebay or try to get these welded up.
Execution time: 0.075 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:21 AM
