Username Post: 235 Throttle/Manifold        (Topic#355240)
46Stylemaster
Reg: 01-04-17
02-14-19 03:12 PM - Post#2759940
- replaced 216 with a 235 in my 46 Coupe
- Exhaust manifold on 216 exits straight down
- ..on 235 it slants to rear and hits throttle linkage
- like to keep linkage if possible
- ...did some 235 manifolds go straight down???
2blu52
2blu52
Reg: 03-12-02
02-14-19 04:48 PM - Post#2759947
    In response to 46Stylemaster
What year 235? On some swaps you can still use the same linkage parts but have to shorten the link between the pedal and it's connection to the bell crank.
"PEACE IS THAT GLORIOUS MOMENT IN HISTORY WHEN EVERY ONE STANDS AROUND RELOADING"
THOMAS JEFFERSON
46Stylemaster
Reg: 01-04-17
02-15-19 07:49 AM - Post#2759987
    In response to 2blu52
235 is a 1958
...Think/thought i had an older 235 in a pile
- valve cover with 4 bolts
- but carb bolts on manifold too narrow and...exhaust exits straight down
[image]C:\Users\BrianLeBl anc\OneDrive\Appraisal\Hi llsboro VDOT\P038\drive-download- 20190221T151207Z-001\IMG_ 1230.JPG[/image]
Edited by 46Stylemaster on 02-21-19 07:35 AM. Reason for edit: No reason given.
46Stylemaster
Reg: 01-04-17
07-17-19 02:54 PM - Post#2770935
Finally, found correct pivot point
but linkage...going from fulcrum to carb (Rochester)
is too long (in pic ) by about 2-3 inches
(tape shows connection point)
https://drive.google.com/open?id=11bZ-Souj6OPZ 9J2x...
Edited by 46Stylemaster on 07-17-19 03:05 PM. Reason for edit: No reason given.
2blu52
2blu52
Reg: 03-12-02
07-17-19 07:08 PM - Post#2770952
Looks like you need to cut it off and rebend the end.
THOMAS JEFFERSON
46Stylemaster
Reg: 01-04-17
07-18-19 04:55 AM - Post#2770967
True...guess i expected it to line up and hesitate to modify original part
2blu52
2blu52
Reg: 03-12-02
07-18-19 07:49 AM - Post#2770977
I may have an original part, I had to modify a after market part provided with headers. Leaving for a short trip but will check when I get home. If I Have one I will give it to you for the price of shipping.
THOMAS JEFFERSON
Execution time: 0.148 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:08 AM
