Username Post: 1972 c10 4 wheel drum conversion        (Topic#355224)
VanillaFace72
VanillaFace72
Loc: 75474
Reg: 10-08-12
02-13-19 12:18 PM - Post#2759839
Sorry if this has been visited before.
My truck has 4 wheel drum brakes. I am looking for a kit to change everything over to disc brakes.
Not only can I not find a full conversion kit but I also am not sure if my front spindles will need to be changed or if the original ones will work with disc brakes.
POWAHHH.
Edited by VanillaFace72 on 02-13-19 12:19 PM. Reason for edit: No reason given.
02-13-19 06:31 PM - Post#2759874
    In response to VanillaFace72
Found this on CPP website.
http://www.classicperform.com/4-piston-kits/4-Pist...
29-41, 42-48, 49-54 Moderator
VanillaFace72
VanillaFace72
Loc: 75474
Reg: 10-08-12
02-14-19 06:01 AM - Post#2759908
This looks like a rear kit.
I am having trouble finding one for the front.
POWAHHH.
Edited by VanillaFace72 on 02-14-19 06:06 AM. Reason for edit: No reason given.
02-14-19 02:32 PM - Post#2759935
OOps didn't notice that it was for the rear.
Take a look around their site and you should find what you are looking for or give them a call.
JimKshortstep4x4
Chevytalk Moderator & "15th Year" Silver Supporting Member
JimKshortstep4x4
Loc: Muskegon, MI, USA
02-14-19 03:50 PM - Post#2759944
What year is your truck? 71 and 72 C-10's had stock disc brakes on the front. If you find a used 72 with the whole front cross member assembly you can have everything including the brake hose brackets that are welded onto the front cross member.
Otherwise there are aftermarket kits that fit the 67-70 trucks. I tried looking up the kits on Eckler's but did not see any kits listed. I checked Classic Parts and they list two kits. There are probably other suppliers that you can check with.
66 Impala SS, 396, TH 400
69 El Camino, 350, TH 350
VanillaFace72
VanillaFace72
Loc: 75474
Reg: 10-08-12
02-14-19 07:03 PM - Post#2759955
Mine is a '72.
It has drum brakes on all points, I have changed them in the past both front and rears. I would like them gone.lol.
I have found conversion kits for '67 all around but not mine.
I guess my question is if I were to go out and get front pads rotors and calipers will I need a different spindle or anything, or will it all go on the same one that holds the drums?
POWAHHH.
JimKshortstep4x4
JimKshortstep4x4
02-15-19 07:08 AM - Post#2759983
Since the calipers bolt up differently, you will need adapters or different spindles. Attached is a picture of two kits that have the adapters so you can use your existing spindles.
Any questions on the kits should be directed to the supplier as my conversions have been in replacing the crossmember assemblies.
Attachment: Scan_0002.pdf (472.51 KB) 20 View(s)
49erman
Loc: So Cal Lower Desert
Reg: 01-02-18
03-02-19 06:26 PM - Post#2761144
  • VanillaFace72 Said:
Mine is a '72.
70 and under (69,68,67) was full Drum Drum and actually 71 had the Option for Disc Brakes or keeping all Drum and then 72 should have been full Disc in at least the front,IIRC right.
Edited by 49erman on 03-02-19 06:29 PM. Reason for edit: No reason given.
Execution time: 0.166 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:11 PM
