Username Post: 63 impala just shuts off when it feels like it.        (Topic#355204)
KellyDay
Loc: Naples
Reg: 02-10-14
02-11-19 05:33 PM - Post#2759669
My 63 2 door hardtop 283 randomly shuts off on me. It has happened at a red light and even when I'm rolling down the street. When i try to start it back up it doesn't even turn over or make any type of sound, just nothing. I believe the oil light comes on but thats it. Usually after cursing up a storm, a dozen push and pulls of the headlight knob and some wiggling of the negative cable, it starts(usually 3-5 minutes later). Sometimes I make it to wherever I'm going but it won't turnover when I get back in it to leave(but eventually does). It seems electrical but I'm not sure, plus I don't know much about that. I cleaned the surface of the ground area with a wire brush but not sure if it did anything since it still shuts off at random. Any advice would be super awesome, just please talk slow
kingkreeton
kingkreeton
Loc: Houston TX
Reg: 04-15-11
02-11-19 05:54 PM - Post#2759671
    In response to KellyDay
The electrical weak point on these cars are the at firewall connections. This is where the front light harness and engine harnesses connect to the fuse box. The are held on by two plastic clips that can easily break or warp. I would start there to make sure your connection is solid. It sounds like you have already checked over your negative battery cable. Just make sure the connection to the engine block is good.
Shane
64 Impala SS:
Chevy Performance 350HO
4 Speed Muncie
Proud member of Big Blue Nation, University of Kentucky Basketball. "Go Big Blue"
gofastwclass
Loc: In the garage
Reg: 08-19-14
02-11-19 05:59 PM - Post#2759674
I agree with Shane on the firewall connection. Mine was bad when I bought my 61 and it would do similar things until I replaced the wiring harness.
1961 Impala mild custom build
Gofastwclass on YouTube
Why buy when you can build it better?
Nitroholic
Nitroholic
Loc: Out West In SoCal
Reg: 05-08-03
02-11-19 08:04 PM - Post#2759691
If jacking around with the battery ground cable helps to get it to restart, I think I'd start by replacing the cable and go from there. I've seen them where they were corroded thru on the inside of the insulation.
'66 C-10 Short Fleetside Big Window
omarine
Loc: San Diego
Reg: 06-29-15
02-12-19 08:17 AM - Post#2759719
I'd repeat those firewall connections.
I went to clean those once, the whole clip was so brittle it shattered in my hand.
Since it was my daily driver, and it happened on a weeknight, I spliced all the wires and crimped them together just so I could get to work the next day. That was about 2 years ago, no issues since.
cheers
61 Impala bubbletop, 283, 2bbl Rochester, generator, points and drum brakes- daily driver
'49 Harley Davidson FL - Panhead
KellyDay
Loc: Naples
Reg: 02-10-14
02-12-19 02:54 PM - Post#2759769
I will give those suggestions a go. I will keep you all posted. Thank you
Execution time: 0.101 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:32 PM
