Username Post: head light switch 1963 Impala        (Topic#355193)
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
02-11-19 02:07 PM - Post#2759646
I need a new head light switch but I only want to use the 'behind the dash' part. I don't mind purchasing entire unit but I do not intend to use the 'knob' and screw on bezel. My dash and all the knobs/switches are original and I want the dash to retain that original appearance.
Can I simply use my original knob and attaching bezel with your 'new' switch?
Thanks.
Pete
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
02-11-19 06:56 PM - Post#2759672
    In response to japete92
Thanks.
Pete
Is your car still stock? Still have the original harness in it, or our Classic Update? If original, you can't use the one we sell in our kits (500332). We have the original available, P/N 01995096. They are about 30-35 bucks.
Donny
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
02-12-19 08:05 AM - Post#2759712
    In response to aawtech
Donny,
The wiring and light switch are original.
So, I will have no problem with the 'behind' the dash section of your part with my original 'in front' of the dash knob and bezel?
Thanks for the reply and part number.
Pete
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
02-12-19 08:08 PM - Post#2759782
  • japete92 Said:
Donny,
Pete
Hi Pete. Not if you use the one I referenced. The kit with the knob, shaft, etc. Would not have plugged into your harness because it is a 64-up designed switch.
Donny
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
02-13-19 07:47 AM - Post#2759804
  • aawtech Said:
  • japete92 Said:
Donny,
Pete
Donny
Thanks Donny!
I did not know there was a difference 63 to 64. Just to satisfy my curiosity, how do they differ?
Also, I need a dimmer switch. I've found your p/n 01995096 and 500286. Will those suffice?
Thanks.
Pete
Edited by japete92 on 02-13-19 08:56 AM. Reason for edit: No reason given.
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
02-13-19 09:26 PM - Post#2759886
  • japete92 Said:
  • aawtech Said:
  • japete92 Said:
Donny,
Pete
Donny
Thanks Donny!
Thanks.
Pete
They are a completely different design. Connectors are different as well. Yes, the two items you mention will fix you up.
Donny
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
02-14-19 11:39 AM - Post#2759920
Thanks.
Pete
Execution time: 0.114 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:55 AM
