Username Post: Lots of Parts        (Topic#355190)
TYTILIDIE
TYTILIDIE
Loc: Colorado Springs
Reg: 10-21-15
02-11-19 01:19 PM - Post#2759643
If anyone would be interested in any of these let me know.
THANKS!!
1959 Rear Frame Mount Pan $400.00
2000 LS Truck Oil Pan $100.00
1959 Impala Headers/Exhaust Pipe $100.00
1959 Bel Air Rear Bumper (NEEDS RESTO) $200.00
1959 Pontiac Boneville? Glove Box Door $50.00
1959 Impala Borgeson Steering Shaft $30.00
1959 Impala Heater Controls $40.00
1959 Bel Air Lower Rear Glass Left Molding $30.00
1959 Impala Steering Wheel Horn Button $25.00
1959 Bel Air Left Rear Arm Rest Mount $30.00
1959 Bel Air Right Rear Arm Rest Mount $30.00
1959 Impala Dimmer Switch $20.00
1959 Bel Air Hood Hinge to Fender Brackets $30.00
1959 Bel Air Dome Light $20.00
1959 Bel Air LH Vent Window Garnish Molding BENT $20.00
1959 Bel Air RH Vent Window Molding $40.00
1959 Bel Ait LH Rear Qtr Glass Track $40.00
1959 Bel Ait RH Rear Qtr Glass Track $40.00
1959 Bel Air DR Qtr Glass Pivot Bracket $30.00
1959 Bel Air PS Qtr Glass Pivot Bracket $30.00
1959 Impala PRNDL $25.00
1959 Bel Air RH Rear Glass Pilar Molding $50.00
1959 Bel Air LH Rear Glass Pilar Molding $50.00
1959 Bel Air Center Trunk Molding $40.00
1959 Impala Rear View Mirror (NEEDS RESTO) $20.00
1959 Pontiac Glove Box Door Hinge $20.00
1959 Bel Air RH Qtr Molding $20.00
1959 Impala Fender Bracket (RESTORED) $50.00
1959 Bel Air Shims $20.00
1959 Bel Air RH Pilar Molding (NEEDS RESTO) $50.00
1959 Bel Air LH Pilar Molding (NEEDS RESTO) $50.00
1959 Impala Rear RH Fin Molding (DENT) $30.00
1959 Impala Rear LH Fin Molding (NEEDS RESTO) $50.00
1959 Bel Air Rear Glass Channel $20.00
1959 Bel Air Rear Glass Channel Roller $20.00
1959 Impala Lap Seat Belt $20.00
1959 Impala Steering Linkage $50.00
1959 Bel Air Rear Glass Upper Molding $75.00
1959 Bel Air Windshield Upper Molding $100.00
1959 Bel Air Rear Glass Lower Molding CENTER $100.00
1959 Bel Air Windshield LH Lower Molding $100.00
1959 Bel Air Windshield RH Lower Molding $100.00
1959 Bel Air RH Lower Rear Glass Molding $50.00
1959 Impala Throttle Pedal Bracket $30.00
1959 Bel Air Interior RH Upper Windshield Molding $40.00
1959 Bel Air LH Lower Widnshield Molding $50.00
1959 Impala RH Trunk Molding BENT $20.00
1959 Impala Lower LH Hood Molding BAD $20.00
1959 Impala Rear Valance Panel Brackets $40.00
1959 Impala LH Trunk Molding DENT $20.00
1959 Bel Air RH Vent Drip Molding $50.00
Tci 4L60/80e Transmission Controller $400.00
Me
Hugomiller
Hugomiller
Loc: Florida and UK
Reg: 05-02-17
03-04-19 06:22 PM - Post#2761316
    In response to TYTILIDIE
Do you know if the heater controls are the same as a 1960? My chrome is a bit pitted.
Execution time: 0.088 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:41 PM
