Username Post: 327?        (Topic#355171)
David1958
Reg: 09-05-18
02-10-19 07:38 AM - Post#2759539
I bought a rebuilt motor and apparently it’s a 327. I’m wondering with the info I submit here if anyone can confirm this?
Casting number behind distributor
13 GM 3914678
Drivers side of block
H-35 678
HB. 636
Passenger side in front of valve cover
781109204 VI005B4
Also on upper rear of block
3
J37
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
02-10-19 11:15 AM - Post#2759555
    In response to David1958
3914678....302.....68....2...Z-28 Camaro
3914678....327.....68....2
3914678....350.....68....2
VI005B4
http://www.nastyz28.com/chevy-engine-code-sta mping...
elcamino
elcamino
Reg: 03-30-00
02-12-19 08:04 PM - Post#2759784
781109204=Con Vin Derivative
7 - 1967 Model Year vehicle
8 - Assembly plant code ?? Could it be a B (B-Baltimore Assembly)
1 - ?
109204 - Last 6 of vehicle vin
VI005B4 Engine plant production code
V - Flint Engine Plant
10 - Oct
05 - 5th day of
B4 - ?? Not used
Check the digits or post a clear pic as some digits don't make sense.
ps - No such thing as a "302 block" - it's the same block used for many other applications; the only thing that makes it a "302" is the crank, rods, pistons, cam, and heads assembled to it, and the suffix code stamped on the pad later - there's nothing "special" about the block.
2018 Polaris RZR S 900 EPS
Execution time: 0.105 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:00 AM
