Username Post: Mid and hesitation        (Topic#355165)
jophes72
Loc: Huntington Beach CA
Reg: 07-19-16
02-09-19 01:53 PM - Post#2759491
So my sbc starts up fine idles fine in the beginning, once engine gets hot it starts to mis a bit at a stop sign and when I take off it hesitates but if I float the pedal it will get up to speed and when I’m cruising it seems fine; maybe a small hesitation if I punch it, New plugs,wires,intake gasket ,carb ,fuel pump and filter. I haven’t done any tests on engine. If anyone has had any similar symptoms or any suggestions:;it would be great;it kinda feels like a fuel problem to me, plugs are tan . The engine sounds strong. Thanks again Joe .
Edited by jophes72 on 02-10-19 09:52 AM. Reason for edit: No reason given.
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
02-10-19 09:51 AM - Post#2759546
    In response to jophes72
What carb ,have you tuned it lately rebuilt, whats your idle rpm ,ignition source points,HEI ?
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY Short Step
63 IMPALA 2/DR HRDTOP 327
02-10-19 10:24 AM - Post#2759548
how hot is hot? seems that you have tuning to do. i would start with timing. try running with no vacuum advance. there are no exact timing numbers to give. every engine will vary. you need to play with the timing to get it to run right according to the way you drive.
Execution time: 0.066 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:10 AM
