Username Post: Rear end ratio (gear ratio)        (Topic#355150)
widall2
Reg: 01-04-09
02-08-19 08:25 AM - Post#2759377
What rear end ratio is recommended for a 1955 car with a stock 6 cylinder with power glide, P215 75 R15 tires that is mostly driven on the highway on 100 mile + trips? Also what is a safe RPM for highway driving that provides long engine life?
TR56210
Reg: 10-28-18
02-08-19 09:45 AM - Post#2759385
    In response to widall2
3.55 should be the stock gear ratio with power glide.
My opinion, engine longevity, is more about over maintenance than in RPM. Have a compression test done to assess overall health. Then check and change oil, cap, rotor, plugs etc per schedule and you are doing everything right. You could temporarily install a tachometer, wire to coil, power and ground, to confirm rpm. If it is the increased rpm when under load, then that’s more a limitation of the transmission not having an overdrive.
Can’t tell from your post if your concern is increasing mpg, highway performance or the power glide being a power glide.
widall2
Reg: 01-04-09
02-08-19 12:00 PM - Post#2759397
    In response to TR56210
Thanks for the response. I am interested in improving gas mileage and not beating up the engine. At 65 MPH my engine is turning about 3000 RPM. My engine is in very good condition and I want to keep it that way. We take several 1000 mile trips per year in this car.
TR56210
Reg: 10-28-18
02-08-19 01:28 PM - Post#2759403
I opted for a 700r4 transmission over a 400, to get the overdrive feature and I hope save gas and more highway friendly.
Other than manual transmission, 3 or 4 speed, most would say the straight 6 is the most economical to drive. I am a fan of the 700r, uncertain as to mounting to a 6 cylinder motor. Maybe some company makes an add on overdrive for the powerglide. The best I think you could get was to drop the rpm from 3000 to maybe 2200.
4.11 gears might help.
Changing rear gear ratio, might get you to around 2000, maybe.
Until that power glide gives up the ghost, I would keep driving it. Once it does, you might have some options that might get you more Mpg.
craig32
Loc: PA
Reg: 08-05-07
02-09-19 03:06 PM - Post#2759492
4.11 gears will hurt, 3.36 gears will help.
Original57
Loc: Houston, TX
Reg: 04-07-09
02-09-19 07:35 PM - Post#2759512
I had the same concern with my '57 but a sml block v8 and 3 speed on the column and 3.55 rear end. I was about to install a 3.08 rear end ($1k)simply to reduce rpm when a friend set me up with the old technology manual trans. Borg Warner R-10. It reduces RPM 29%. Basically adding a 4th gear. Has idiosyncrasies,
but worth it. I did not have to alter drive shaft
I DO NOT know if the old R-10 will fit on a 6 cyl without research.
a cheap option is to get tall tires on the rear but your speedometer reading & riding height would be off but you can check mph via GPS.
Some guys on chevy talk reeaallyy helped me get mine going. The were so knowledgeable, I could look up the old posts and you could ask them questions.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
02-10-19 03:41 PM - Post#2759571
If the engine is in good condition 65 to 70 MPH is a safe speed. A 3.36 will reduce your engine speed by only 5%. A 3.08 will be like have a 1000 pound trailer on the back power wise. 3000 is a safe RPM for that engine.
widall2
Reg: 01-04-09
02-11-19 09:48 AM - Post#2759620
Thanks to all of you for your input. From this and some from friends I think I will go with changing to a 3.36 gear. My ’55 presently has a 3.70 gear, the car was originally purchased by a lady school teacher and may have been ordered special. I used a cheap tach to check RPM so my RPM numbers may be incorrect. I like the ides of an automatic with overdrive however adaptors would have to be used and then the final ratio I believe would be too fast for the horsepower of the 6 cylinder. I have several late 50’s 3 speed plus overdrive transmissions and I would go that way if I was 20 years younger. I even have a 4 speed light duty transmission (I think a Saginaw) and a heavy duty curved side three speed plus overdrive unit that, based on articles that I have read, can be adapted to the 4 speed with minor alterations. Some day I will dig out the article and put this stuff up for sale.
One more question, will 3.36 gears fit in the ‘55/’56 third member? I have read that they will not because the pinion gear is so big that the ring gear can not be moved over far enough. That article says the third member must be ’57 to ’64. Have any of you had any experience with this?
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
02-11-19 12:19 PM - Post#2759641
Chevrolet had no option for a 3.70 ratio in a Power Glide.
With a Power Glide you will have about a 4% gain in engine speed due to the torque converter. That is why lock-up converters were used. I am sure you have a 3.55 - the diff. number stanped into the front of the housing on the right side will ID the ratio.
radioheaterwsw tires
Reg: 08-24-14
02-16-19 03:43 PM - Post#2760060
    In response to Gene_Schneider
Hi Gene:
From many years ago, being a high school'r having a used Powerglide equipped tri-five car, we kids always thought that there was about a 10% slip in these transmissions. I've never seen any printed reference to the percentage of slip. Is it so stated in any literature?
Also, is the 4% slip constant or fixed, regardless the vehicle speed or whether in low gear or drive? I always figured the least amount would be driving down a level highway at cruising speeds of say 50-70 mph. And the most going up a grade in low gear.
Would so appreciate your sharing your knowledge about this.
I always enjoy the info share on this site about old Chevies.
02-16-19 06:21 PM - Post#2760070
Your information is correct. If you use a 3.36 (or 3.08) gear ratio you must use a 57-64 3rd member case. Same would be true of any gear set that's made for a 57-64 3rd member. You must use 55-56 gears if you have a 55-56 3rd member case!
Good news is that any complete 57-64 3rd member can be used in a 55-56 housing. If it is a posi you must shorten each axle shaft 1/8".
f.i.57chevynut
f.i.57chevynut
Loc: Granada Hills, CA
Reg: 03-04-09
03-01-19 09:48 PM - Post#2761091
    In response to Rick_L
My experience with 6 cylinders in 57's is that the taller the gear the better. The 235 has a 3 15/16 stroke, good for a tractor but bad for rpm. I'd use 3.08 gears. I have a 3 speed bar that I put a 3 speed overdrive in. It was great around town, 20mpg with 4.11 gears and P235/75R 15 tires.(tall) I took it on the road but at highway speed it only got 23mpg, not liking the rpm. Towing a 57 wagon back from Colorado with a tow bar, it got 17, lower speed.
Tom Ordway tom@57chevys.com If you don't drive it, why have it?
http://www.americantorque.com/page/0/139/
shoeboxpaul
shoeboxpaul
Loc: New Freedom, PA
Reg: 08-15-16
03-18-19 02:32 PM - Post#2762406
I think that you will find that these engines usually consume gasoline at a steady pace. I had a 72 Chevy van in excellent shape, wanted better mileage the same as you. I changed gear ratios as it originally had a stump puller. I spent a lot of money to get the same gas mileage. I went as far as to work over the carb making sure no vacuum leaks and that machined surfaces were level, complete tune up, new wires, even pulled the distrubutor and made sure the shaft bushing was not wallowed out and put it back after a thorough cleaning. Last effort was to install a Melling 3/4 race camshaft. Not only did I not notice a performance change, it got the same gas mileage. Only thing I did not do was pull the head and do a valve job. With excellent compression and a super clean engine (internally), smooth idle, no smoke out the tailpipe, I did not see a need to pull the head.
All I am saying is, don't get your hopes too high about increasing fuel mileage.
557B2100
557B2100
Reg: 06-02-13
05-14-19 09:27 AM - Post#2766372
    In response to shoeboxpaul
If you are interested, Langdon's carries this adapter kit for the TH 350, 2004R, 700R4 transmissions: http://www.langdonsstovebolt.com/store/#!/Transmis...
Execution time: 0.122 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:33 PM
