Username Post: 82 c10 305H ENGINE IGNITION MOD QUESTION        (Topic#355145)
pmagrum
Loc: Lakeland, Fl
Reg: 02-06-19
02-07-19 04:56 PM - Post#2759334
I HAVE A 82 C10 SILVERADO WITH A 305h engine. It has a vacuum advance. My eci module is a 5 pin mod but the extra input on the pickup side is not used. The unused input is labeled knock sensor on info I have found. Wondering if this is the correct mod for this engine. Any input would be appreciated.
02-07-19 06:00 PM - Post#2759340
    In response to pmagrum
Welcome to AF. Doesn't sound like the right one, sounds one for an ecu controlled engine. Check it out on Rockauto.
Edited by Shepherd on 02-07-19 06:02 PM. Reason for edit: No reason given.
Liberty Valance
Liberty Valance
Loc: Euless,Texas
Reg: 07-21-14
02-07-19 07:30 PM - Post#2759349
Welcome.
1974 Cheyenne 10 LWB 350/TH350/AC/4 BBL Quadrajet
pmagrum
Loc: Lakeland, Fl
Reg: 02-06-19
02-08-19 07:09 AM - Post#2759365
I had looked there. They show a four and a five pin for the H engine. Been running for years with the five pin, Just didn't know if it should have the four. Noticed the unused pin when rebuilding the distrib.
pmagrum
Loc: Lakeland, Fl
Reg: 02-06-19
02-08-19 07:10 AM - Post#2759366
    In response to Liberty Valance
thank you
Senior Chevytalk Moderator
02-08-19 08:11 AM - Post#2759376
Welcome to the site. Early ‘80s had ESC modules. I removed the module on my 83. Read the sticky at top of this forum. It explains how to remove electronic spark control. Basically it would change timing if spark knocking was detected.
pmagrum
Loc: Lakeland, Fl
Reg: 02-06-19
02-08-19 05:57 PM - Post#2759427
Don't believe I have a ESC mod if I did wouldn't there be a lead or two from it? I only have two wires from the pick up going to the 3 pin side and wires from the cap to the two pin side. I have a vacuum advance on the dist. thanks for the help. there are only three wires to the cap batt, ground , and tach on mine
Edited by pmagrum on 02-08-19 06:04 PM. Reason for edit: No reason given.
02-08-19 06:07 PM - Post#2759433
Is this a carbureted engine, if so, no esc.
pmagrum
Loc: Lakeland, Fl
Reg: 02-06-19
02-09-19 05:38 AM - Post#2759458
Thank you, Yes it is . Had a Rochester quadrajet but I replaced it with a Holly. still trying to figure out if it should have a 4 pin instead of the 5 pin which was in it.
kzhurley
kzhurley
Loc: Millersburg,Ohio
Reg: 01-02-12
02-12-19 06:26 AM - Post#2759703
Sounds like you don't have the other parts to go with the 5-pin module for esc so it wouldn't matter 4 or 5 pin module then.
Unless of course youre looking for those parts to restore the esc function, which I ASSume not since you've put a Holley on it.
1950 Styleline Deluxe 2-door sedan..
348 tripower/NP833 4-Speed/3.73
1950 Styleline Deluxe 4-door..
Vortec 4200 I-6/4l60e/3.42/current project car
1956 Cadillac Coupe de Ville 500 efi/4l80e
1987 GMC R1500 Sierra Classic
454 tbi/700r4/3.42
02-12-19 07:25 AM - Post#2759706
    In response to kzhurley
Do you have wiring diagrams? Wiring diagrams are available for all models.
Go here: http://forum.73-87chevytrucks.com/smforum/index.ph...
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
02-18-19 09:03 PM - Post#2760263
I inherited my 82 Silverado almost 20 years ago. It was a carburetor 305 with ESC. Course the 305 was bad (spun main bearings), and I replaced it with a 327 I had. Out came ALL the ESC, and SMOG equipment. I did reuse the 5 pin HEI distributor, and just replaced the 5 pin with a 4 pin. All the engine has now is a PCV control setup now, and the 327 was replaced with a Target Master 350 10 years ago, that dropped #8 exhaust valve right after the warranty ran out. Truck has a stroker 305 in it now; 334 CID due to a .030 overbore, cut down 400 crank, 400 rods, and a forged 305 piston. I am Butch/56sedandelivery.
Execution time: 0.113 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:36 PM
