Username Post: 1962 Fuse Block        (Topic#355121)
junky
Loc: Northeast CT
Reg: 06-27-10
02-05-19 09:22 PM - Post#2759179
I was looking at the diagram of the fuse block of a 1961 in the '61 service manual. At the bottom right of the 1962 fuse block, there are 2 openings, but the factory didn't put the electrical connections into them. In the 1961 book, it shows this as the place to hook up the spotlights. Is it possible to add these to the 1962 fuse block? If so, where would I get the terminals, and how would I complete the wiring? I was thinking that I could use the accessory terminal, but I already have plans for that terminal.
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
02-06-19 04:07 PM - Post#2759234
    In response to junky
Ask Don Bock at American Autowire. I got connections from him/them for a connector that came loose on a new harness.
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
62 Imp CV SS 327/300HP 700R4
62 ImpHT SS 409/482 stroker 4 spd
62 Imp SS 409 - 5 spd Convertible under frameoff
Web http://paulstensland.com/
Tri5man
Tri5man
Loc: Possums Crotch, KY
Reg: 06-26-07
02-06-19 04:40 PM - Post#2759237
    In response to pvs409
Auto Zone has the connectors you need.
junky
Loc: Northeast CT
Reg: 06-27-10
02-07-19 02:45 PM - Post#2759327
Today, I checked each terminal on the right for power, and learned that the ACC. terminal is dead. Checked all the fuses, and they are all good. Does anyone know where this terminal gets its power from? I was thinking that it might be fused, but can't find any other fuses, except for the air conditioner under the hood, and that one is disconnected until I finish putting the A/C back on the engine.
55Brodie
55Brodie
Loc: Little River, SC
Reg: 12-26-15
02-08-19 06:41 AM - Post#2759369
Junky:
The ACC terminal and the LPS terminal next to it are both powered by a 20 gauge gray wire that is part of the instrument lamps circuit. That circuit receives its power from a 16 gauge dark green wire off of the headlight switch. All these circuits are protected by the top left instr.fuse.
fander
fander
Loc: Hot Springs South Dakota
Reg: 04-28-12
02-08-19 09:02 AM - Post#2759386
    In response to 55Brodie
What do the letters "LPS" mean.
55Brodie
55Brodie
Reg: 12-26-15
02-08-19 09:30 AM - Post#2759390
    In response to fander
Lamps, I assume.
junky
Loc: Northeast CT
Reg: 06-27-10
02-10-19 11:40 PM - Post#2759603
  • 55Brodie Said:
Junky:
I checked both of these terminals, and they are only live, when the headlamp switch is pulled out. I need 2 live terminals when the ignition is off or the headlight switch isn't pulled out. One will be for the spotlight and the other for the 4 way flasher. Checking the1962 accessory instruction manual (page 430) it says to plug into the terminal marked "spot-ant". Looking in the 1961 FSM, I see these markings on the fuse block that is shown there (page 9-51). Looking in the 1962 Shop Manual Supplement, it doesn't discuss the fuse block, however on page 9-30, it indicates in the wiring diagram that these are blank terminal blocks. I am looking for a couple of "pig tails" from a discarded fuse block so I can add these to my fuse block, or a picture of what they look like. I have been searching for these terminals for a few days, without any luck in finding them. Once I have them wired in, I will protect the circuits with inline fuses. Thanks Junky
02-11-19 06:15 AM - Post#2759607
I believe they use the standard Packard 56 male terminal. Link to terminal.
55Brodie
55Brodie
Reg: 12-26-15
02-11-19 08:40 AM - Post#2759618
Junky,
I think I can fix you up from my old fuse block. I think I can safely remove the bus bar terminal for ACC/LPS.
Send me a PM with your address. It may take me a day or two to get it in the mail.
Execution time: 0.106 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:29 PM
