Username Post: This ones got me STUMPED        (Topic#355119)
marcgyver77
Loc: United States
Reg: 03-29-14
02-05-19 07:14 PM - Post#2759158
Trying to figure this out... '97 Express, 5.0 (have had since new). Went from average 18 MPG to barely 13 MPG.
Engine runs strong, idles good, accelerates good. 20 psi vacuum at idle.
Replaced: Plugs, wires(routed un-touching), cap, rotor, upstream & down stream O2 sensors, muffler, air filter, fuel filter, PVC valve, vacuum hoses
Plugged off EGR to eliminate that as a problem(appeared that it was working correctly).
Cleaned Mass air (with correct cleaner).
Run Sea Foam thru gas tank and thru intake via vacuum line.
Timing advances. Used programmer to advance timing to various settings with little results.
No check engine codes (other than EGR after plugging)
Checked MPG both with speedometer and GPS.
Other than heavy carbon build up inside tailpipe from running rich (or checking MPG on my 160 mile weekly commute), you would think its running good...
Any ideas
454cid
Loc: West Michigan
Reg: 02-18-12
02-05-19 07:28 PM - Post#2759161
    In response to marcgyver77
Any ideas
What temperature does the PCM think the engine is? If your coolant temperature sensor is bad (or the wiring) and the PCM thinks the engine is cold, it's going to run rich.
99 K3500 RCLB
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
02-05-19 08:05 PM - Post#2759166
    In response to 454cid
agreed.
Look at the ECT readout on a scantool.
when the engine is cold the coolant temp should be within 4*+- of ambient temperature.
Old School GM fan FOREVER
marcgyver77
Loc: United States
Reg: 03-29-14
02-06-19 02:16 PM - Post#2759221
I hurried home to plug in my scanner even though the engine was at operating temp. The coolant temp showed 178 Deg , the intake temp was at 111 and rose to 121 while sitting there idling. I scrolled thru...intake vacuum good, mass air was at 6-7 at idle... most of the other (bank 1, bank 2, etc) was Greek to me. I could write them down if it would help diagnose the problem.
I was optimistic about it being an easy fix...Lol
I can wait till it cools off if it has to be checked cold...
454cid
Loc: West Michigan
Reg: 02-18-12
02-06-19 02:49 PM - Post#2759225
That's a little low, but not much. Do you only have a 180 degree thermostat instead of a 195?
That's a little high... the book says 5.80, for the 5.0/5.7, so if you're seeing 7 at idle, it could be the PCM is adding fuel to try to make the mixture right. I had the opposite problem... my MAF was reading low, at only 2. I got a salvage yard MAF.
I'm not very experienced in this kind of thing, so don't take this as definitive.
You could try unplugging the MAF, and see if anything changes. The PCM will switch to speed density mode.
99 K3500 RCLB
02-06-19 03:23 PM - Post#2759229
A lazy o2 sensor can cause and not set a code until it caused the fuel map to go out of it's program limits.
marcgyver77
Loc: United States
Reg: 03-29-14
02-06-19 04:25 PM - Post#2759235
It is only a two mile drive from work.
So I went back to update/clarify readings:
At idle, in neutral, 666 RPM, MAF 5.7 to 5.9
At idle, in neutral, AC on, 695 RPM, MAF 7.1 (AC was on when I checked it earlier... hot day today in Georgia).
At 157 degrees, thermostat opened ie. 160 thermostat.
Didn't understand what you meant by unplugging MAF.
Thank you for your help...
marcgyver77
Loc: United States
Reg: 03-29-14
02-06-19 04:34 PM - Post#2759236
I replaced both of the upstream (2 months ago) and the one downstream (last week) with Bosh sensors. But with everything made in China...??? who knows???. Although they did not make a difference.
02-06-19 06:09 PM - Post#2759241
Why a 160 thermo, you need 195 for proper ecm controls for the fuel map and timing.
454cid
Loc: West Michigan
Reg: 02-18-12
02-06-19 06:15 PM - Post#2759242
That sounds better.
I'd get that out of there. Put a 195F in it, or at least one in the 180's but it was programed for 195F unless you've had the PCM changed.
The truck will run without it. The computer switches to Speed Density, but never mind, because it sounds like your MAF is in spec.
99 K3500 RCLB
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
02-06-19 07:17 PM - Post#2759248
How long has that 160 stat been in there?
marcgyver77
Loc: United States
Reg: 03-29-14
02-06-19 09:19 PM - Post#2759262
    In response to rockfangd
I am not sure. I will have to look at my receipts. I replaced the water pump 09/2015 along with the hoses and fan clutch. I think I would have replaced the thermostat while I was right there...and got the right one called out for it...
I will get a new one tomorrow and change it out before my weekly commute home (I work out of town in Savanna four days and go home on the weekends).
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
02-07-19 10:16 PM - Post#2759357
Gonna go out on a limb here and suggest part of the problem is Bosch O2 sensors.
Greg
'00 Explorer XLT 4.0 V6 Auto
4dr 57
4dr 57
Loc: Texas Hill Country
Reg: 11-10-04
02-08-19 09:21 AM - Post#2759388
Is your engine an OBD1 system? Do O2 sensors come in two flavors like OBD1 and 2?
Stan
02-08-19 10:18 AM - Post#2759394
    In response to 4dr 57
97 should be obd11, most sensors are heated so usually 4 wires. If 2 wire or one, not heated.
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
02-08-19 10:40 AM - Post#2759396
‘97 is OBD2
Greg
marcgyver77
Loc: United States
Reg: 03-29-14
02-08-19 07:34 PM - Post#2759444
Well... I replaced both the thermostat (with a 195 degree) and the coolant temperature sensor.
Filled up, left Savanna to go to Concord, about 3 1/2 hour drive, temperature came up to between 194 to 197 degrees. Idle dropped to 620 RPM, MAF was 5.8, seemed to run good.
Drove 280 miles, put 20 gallons of gas in, 14 MPG...
STILL STUMPED
marcgyver77
Loc: United States
Reg: 03-29-14
02-08-19 07:52 PM - Post#2759445
    In response to CowboyTrukr
Is there an issue with the Bosch sensors? Replacing the original O2's out with the Bosch ones didn't (seem to) make a bit of difference (nether better or worse).
Yes, it is OBD2
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
02-08-19 08:43 PM - Post#2759448
I don't know how you got 18 before, but 14 is pretty good. I've had a few 350 trucks and 14 was what they got. The Express van probably has 1000lbs on the pickups. The 305 is smaller, but it works harder. They don't get better mileage than a 350 and a lot of times they get worse. I'd be happy with 14.
Jeff
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
02-08-19 09:12 PM - Post#2759450
    In response to bowtie44s
14 is good on my 5.7l.
I dont think I have ever gotten any better than that. OBD1 though
454cid
Loc: West Michigan
Reg: 02-18-12
02-08-19 09:56 PM - Post#2759452
Have you changed anything else, like tires (possibly size), or the way you're calculating your mileage? How fast are you driving? Have you always driven that speed? You're mileage will drop over 65mph.
99 K3500 RCLB
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
02-09-19 12:19 AM - Post#2759453
Marc, many here have experienced problems with the Bosch O2’s. OEM is best.
Greg
junky
Loc: Northeast CT
Reg: 06-27-10
02-09-19 09:17 AM - Post#2759469
I bought a Bosch O2 sensor for my wife's PT Cruiser on eBay, and the scan showed that it was "defective", even though it was new in what I believed to be a Bosch packaging. Bought an OEM from the Chrysler dealer, which was also a Bosch, and problem solved at 3 times the cost. I believe that a lot of what is being sent into the country might be counterfeits, or those that don't pass quality control (if there is such a thing) in China.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
02-09-19 09:27 AM - Post#2759470
    In response to junky
I do not buy bosch anything. I like to stick with Denso for o2 sensors
454cid
Loc: West Michigan
Reg: 02-18-12
02-09-19 10:47 AM - Post#2759474
My rear O2 sensors are Bosch, and I don't believe I've had any problem with them, however, they don't change the way the truck runs. Only the fronts to that.
It's weird that Bosch plugs and O2 sensors have a bad reputation when they're the biggest OEM producer of parts in the world. Must be their after-market line isn't the quality that the OEM parts are.
I have a pair of Bosch O2s for the front that I've never installed, as I couln't get the originals out at the time. It's irritating to think I really should buy different new ones. I wonder if NTK would be any good.
99 K3500 RCLB
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
02-09-19 11:07 AM - Post#2759477
The only experience I have with Bosch is spark plugs. I told the wife to pick me up some AC Delcos. They were sold out but the parts store guy told her these Bosch were way better. Against my better judgement I put them in. I had a terrible miss. I took them out and put ACs in and it ran great.
Jeff
Edited by bowtie44s on 02-09-19 11:07 AM. Reason for edit: No reason given.
marcgyver77
Loc: United States
Reg: 03-29-14
02-09-19 04:38 PM - Post#2759502
Sorry Bowtie, not a response to you but a reply to earlier POSTS
Here is the advertised specs for the 1997 Express cargo van:
ENGINE SPECS – 5.0 4AT (223 HP)
CYLINDERS
V8
DISPLACEMENT
5012 cm3
POWER
164 KW @ 4600 RPM
223 HP @ 4600 RPM
220 BHP @ 4600 RPM
TORQUE
280 lb-ft @ 2800 RPM
380 Nm @ 2800 RPM
FUEL SYSTEM
Electronic Injection
FUEL
Gasoline
PERFORMANCE SPECS
TOP SPEED
ACCELERATION 0-62 MPH (0-100 KPH)
FUEL ECONOMY SPECS
CITY
14 mpg US OR 16.8 L/100Km
HIGHWAY
19.4 mpg US OR 12.1 L/100Km
COMBINED
14.1 mpg US OR 16.7 L/100Km
Here is a post from a “Gold member”: My 6,200 lbs 1997 Express G1500 Conversion van running the factory 4L60E and 3.42s in the 8.5" 10-bolt it would pull down 18-20 mpg highway at 70-75 mph but it was GUTLESS compared to the way it runs now…
I just put on my third set of Michelin LTX tires. The speedometer was reprogrammed to tire size and matches my GPS within 1 mile of 170 mile weekly commute home.
The way I have been checking my mileage has been like this:
• Fill up to the second shutoff click in Savanna when I leave
• Fill up to the second shutoff click in Byron, 170 miles away (interstate with cruise control)
• Miles divided by gallons = MPG (I’m 61, so that’s the old math way…Lol)
The best mileage was last week, when for the first time, I programmed it for premium fuel (max timing advance), running at 85 MPH, used 11.8 gallons.
Two weeks ago, running 75 MPH, regular fuel program, used 12.3 gallons
On the way back, running 70 MPH, used 12.8 gallons.
So I’m going to rule out O2 sensors just for the moment, seeing there was no difference when I replaced them with the questionable Bosch ones. Still could be an issue.
The new Engine Temperature Sensor brought the reading to the PCM up from 178 to 197. Lowered the RPM down to 620 from 660. MAF at a steady 5.8
Mileage went up a little bit.
What else could be wrong?
Why do I get better mileage at 75+ MPH than under 70 MPH.
Fuel injectors worn out? Spraying or leaking fuel into the intake? Wouldn’t the PCM read that and compensate for it, or emit a “Check Engine”?
STILL STUMPED
Edited by marcgyver77 on 02-09-19 04:43 PM. Reason for edit: No reason given.
454cid
Loc: West Michigan
Reg: 02-18-12
02-09-19 04:48 PM - Post#2759503
...I programmed it for premium fuel (max timing advance), running at 85 MPH, used 11.8 gallons.
So you changed tires size? How are you "programming" the PCM?
99 K3500 RCLB
marcgyver77
Loc: United States
Reg: 03-29-14
02-09-19 05:02 PM - Post#2759505
I am using factory tire size. Using a Jet programmer to enter the actual tire diameter size. Checked accuracy by the Hwy mile markers and my GPS.
The Jet programmer has three fuel programs to choose from (regular, mid grade, premium) if you don't want to do a custom program. I thought i would give it a shot to see what it would do. (Can't set the timing the old school way- turn it till it clatters and back it off...Lol)
Edited by marcgyver77 on 02-09-19 05:14 PM. Reason for edit: No reason given.
02-10-19 08:48 AM - Post#2759541
what is your fuel pressure? does it hold pressure after the engine is turned off? o2 sensor readings should fluctuate allot when blipping the throttle or adding propane to the intake
Execution time: 0.067 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:18 AM
