Username Post: Surprise Transmission Fluid Puddle        (Topic#355114)
blue56
blue56
Loc: LaGrange, KY
Reg: 05-24-03
02-05-19 07:59 AM - Post#2759074
Sunday morning I was greeted by a surprise puddle of transmission fluid under the 56. It was on the passenger side, just behind the tire. The car has not moved or been started since mid-December. We had a cold spell, but I don't remember seeing the thermometer in the garage go below 40Fs. The leak seems to have stopped now.
I got underneath with a light and the only droplet I could see was at the bottom of the transmission fill tube.
In the 14 years I've had this car, this is the first time I've seen this. Is this a somewhat normal thing or is it something I should be concerned about and look toward fixing?
Attachment: Transmission_Leak.jpg (79.67 KB) 6 View(s)
Transmission Leak 2/3/2019
You can't drink all day...
...if you don't start in the morning.
Travs55
Travs55
Loc: Houston, Texas
Reg: 03-11-05
02-05-19 08:40 AM - Post#2759085
    In response to blue56
My ‘55 Powerglide does the same thing if I don’t start it for several days
Jalapeno
Jalapeno
Loc: The Republic of Texas
Reg: 04-30-00
02-06-19 08:36 PM - Post#2759254
After it sits a couple weeks, if you crank it up, move it a little, then shut it off, the fluid will come burping up that fill tube.
Jalapeno
Lee T
Reg: 07-05-12
02-07-19 02:59 AM - Post#2759267
If you are not working it hard, you can run it a little low on fluid to prevent that happening.
blue56
blue56
Loc: LaGrange, KY
Reg: 05-24-03
02-07-19 07:07 AM - Post#2759276
    In response to Lee T
Thanks for the replies. I'm glad it doesn't sound like anything major.
george88gta
george88gta
Loc: new york
Reg: 04-23-03
02-07-19 11:05 AM - Post#2759301
You may want to try this. "Burping" is common, this kit is supposed to fix the problem.
https://www.classicchevy.com/chevy-in-line-one-way ...
Todd M
Todd M
Loc: PA
Reg: 08-21-03
02-07-19 04:42 PM - Post#2759332
    In response to george88gta
Mine has been burping for years with that valve installed.
1957 2-dr BA HT currently 283 PP http://www.picturetrail.com/tbmax57
george88gta
george88gta
Loc: new york
Reg: 04-23-03
02-08-19 01:01 PM - Post#2759401
    In response to Todd M
Interesting, yet another "fix" that doesn't work. Back in the '60s, I had a 55 convertible and then a 57 hardtop. Both powerglides and no strange leaks. Guess I was lucky.
Rustchips
Rustchips
Loc: DFW Texas
Reg: 02-24-05
02-08-19 07:41 PM - Post#2759441
If you drive them daily, or at least once a week you should not have that problem. My 55 sits way to long between drives and it burps fluid.
Cleon
1928 Chevy Coupe
1955 Chevy Bel Air HTP
1970 El Camino
1990 F##d Mustang Convertible
george88gta
george88gta
Loc: new york
Reg: 04-23-03
02-10-19 04:40 AM - Post#2759526
    In response to Rustchips
Cleon
Yes, both daily drivers. If we only knew then what we know now!
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
02-10-19 03:36 PM - Post#2759570
If the engine was not started and the puddle appeared it is not burping. The fluid in the top half of he converter drains down and over fills the sump. Then the fluid leaks out around the kick-down lever seal because the fluid is way over full. Converter will refill when engine is running and takes about three minutes.
blue56
blue56
Loc: LaGrange, KY
Reg: 05-24-03
02-12-19 09:37 AM - Post#2759721
    In response to Gene_Schneider
Thanks Gene. After seeing a second, or continuing, puddle after wiping up the first one, this makes sense. I would think the burping would be a one time thing. I'll look closer for signs of the source and start the car to let it run for a while.
Execution time: 0.147 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:03 PM
