Username Post: Stock gas tank removal        (Topic#355095)
Denver56BelAir
Denver56BelAir
Loc: Parker, Colorado
Reg: 01-11-05
02-04-19 12:19 PM - Post#2758987
I need guidance on removing a stock gas tank on a 56 Belair. I need to check the inside to see if things are clogged.
Paul
Parker, Colorado
56 BelAir Post, T56, 327, 4:11, Astro custom chrome steel wheels,
http://tinyurl.com/56belair
chevyman57B.C.
Reg: 08-29-12
02-04-19 12:56 PM - Post#2758993
    In response to Denver56BelAir
unhook the wire to the sending unit, disconnect the gas line that goes to the tank.
Undo both gas tank straps pull tank off the filler neck
I just did my 57 all is fresh right now.
A lift car lift would be nice. I know !!!! I have one.
Larry
Pull sending unit out take a good in side with a light
02-04-19 03:51 PM - Post#2759019
Link to gas tank mounting.
Edited by acardon on 02-04-19 03:53 PM. Reason for edit: No reason given.
fuzz1957
Loc: NE IA
02-04-19 06:03 PM - Post#2759032
    In response to acardon
I would drain gas. Be very careful when working with your sending unit. Very easy to break the fragile soldering where tube goes into unit. Good luck.
Fuzz
MAGA
Original57
Loc: Houston, TX
Reg: 04-07-09
02-05-19 09:40 PM - Post#2759174
    In response to fuzz1957
I have taken my tank off my 57 at least 3 times. When the imported sending unit stops sending because the brass float gets a pin hole in it, that's frustrating. I suggest you look for a plastic float while the sending unit is out. It's been about 6 years ago I replaced it, there was a Ford thick plastic float that fit perfectly.
I know that I am particular, but, from a completely empty tank, I added 1 gallon from can, then tried to start. Then added 1/2 gallon at a time and try to start it, to determine how much was below the suck line. Then make a pictorial of your gage and note on it where your needle is. I chose to add 1 gallon at a time noting where the gage needle on my diagram until completely full. This way, when I am traveling, I can always tell how many USABLE gallons I have left, times my 14 mpg gives me range.
Execution time: 0.086 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:51 PM
