 Page 2 of 2 <12
Username Post: Window channels and vent window gasket        (Topic#355091)
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
03-06-19 04:49 PM - Post#2761476
    In response to dsacton
  • dsacton Said:
The originals were clipped in place, but that is not an option on the replica.
I took a little different tack since I was able to reuse the original metal part of the channels that still had the original clips on it....and I was only doing one window. I cut synthetic felt that you can buy at about any fabric store. I determined that 3 layers would approximate the thickness of the original felt. I sewed it together using heavy upholstery thread then set it into the channel using GE water proof silicone from a 2.8 FL OZ tube. I let it cure overnight while the glass was inserted into it. The residual silicone you see on the stainless bead stripped away cleanly once it had cured.
Attachment: Three_Felt_Layers_.jpg (2.96 MB) 0 View(s)
Attachment: Stitched_Felt.jpg (3.48 MB) 0 View(s)
Attachment: Felt_Siliconed_In_Rail.jpg (3.06 MB) 0 View(s)
1951 Fleetline
Chevs of the 40s
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
03-06-19 07:40 PM - Post#2761489
    In response to RAM_51
Very nice work! The fuzzies I have are already in the channels and I am replacing the whole thing, so no clips.
Scott Acton
1954 Chevy Bel Air 2-door
http://www.my54chevy.com
RAM_51
RAM_51
Reg: 12-28-02
03-06-19 07:52 PM - Post#2761491
  • dsacton Said:
Very nice work!
Thanks. This is one route to go if the metal on your originals are still useable. I have seen some channels that are so rusted and disintegrated that this method would be impossible. One last photo of the reinstalled channel. The window is now held nice and snug...no rattling or chance of breakage.
Attachment: Reinstalled_Felt_Window_Channel_.jpg (3.05 MB) 4 View(s)
1951 Fleetline
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
03-15-19 09:18 PM - Post#2762192
Good evening!
I'm putting the glass back in my door and I've run into a dilemma: if I glue the window channel (the bendable section) into the door, how am I ever going to replace the glass if I need to? I can loosen up the wing a bit, but it is still constrained. Is there a trick to getting the window in and out without removing the channel?
Scott Acton
johnwd98
johnwd98
Loc: Little Falls, MN
Reg: 09-05-10
03-16-19 06:40 AM - Post#2762216
  • dsacton Said:
Good evening!
I may be misunderstanding the post, but my experience is the window is easily installed and removed with the window channel staying in the door. The wing window goes in last, or is removed first when removing the door glass, and is a little trickier to get in and out.
1950 Fleetline, 355 TBI, mild cam, 700R4, 3.73 posi rear Blazer axle, MII front. Remote door and trunk locks, GM cruise control, A/C,
Edited by johnwd98 on 03-16-19 06:43 AM. Reason for edit: No reason given.
RAM_51
RAM_51
Reg: 12-28-02
03-16-19 08:09 AM - Post#2762222
    In response to johnwd98
I believe the wing window can stay in and be swung open, but the divider between the wing vent and the side window MUST come out. In other words the front channel must be removed in order to tip the window forward for removal.
1951 Fleetline
03-16-19 08:26 AM - Post#2762223
In the glass shop we'd put the wing vent/divider into the door and just sort of let it dangle there, using tape to prevent any paint damage while the glass was put into the slot. We'd then line everything up into the correct channels, and bolt in the wing vent/divider at the very last.
AFTER it was all together we'd grease the steel channels, and spray 100% silicone into the fuzzy channels and adjust everything and tighten all bolts.
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
03-16-19 02:10 PM - Post#2762245
Thanks, guys. I will give it a shot. With the wing loose, it frees up space at the bottom on the wing-side channel, but still constrains the glass near the top of the door. I may be able to finess it a bit.
Scott Acton
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
03-17-19 08:44 PM - Post#2762333
Robert (or anyone else too),
Do you know if the stainless is supposed to tuck in as shown, or extend into the channel? Thanks. I got the window in OK, w/o removing the channel, after completely disengaging the wing.
Attachment: IMG_4481.JPG (71.56 KB) 0 View(s)
Scott Acton
03-17-19 09:18 PM - Post#2762338
Sometimes we tucked them in, similar to the picture, sometimes we cut them off flush so they would meet the vertical piece, but we never ran them into the channel.
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
03-18-19 08:44 AM - Post#2762365
Thanks. I can smash it a bit more and tuck it. I cut the other end flush.
Scott Acton
50hotrod
50hotrod
Reg: 07-25-11
03-18-19 09:46 AM - Post#2762369
I used Permatex High Temp RTV Silicone to install my channel 4 years ago.
1950 CHEVY 2 DOOR 327 TRI POWER FENDERWELL HEADERS HEIDT FRONT SUSPENSION 700R4 TRANS 411 REAR
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
03-18-19 11:26 AM - Post#2762378
    In response to 50hotrod
I hope regular RTV works since that is what I used! I probably should have experimented, but I really want to get this car on the road.
Scott Acton
Chevs of the 40s
 Page 2 of 2 <12
Execution time: 0.062 seconds.   Total Queries: 20   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:41 AM
