z28summit
Reg: 06-11-14
02-02-19 04:28 PM - Post#2758849
Does anyone know what this inner little shelf does? Mine has seen better days and I am wondering if I even need to replace it. I dont even know if it was welded to the outer quarter or not.
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
02-02-19 04:47 PM - Post#2758850
In response to z28summit
It gives you something to attach the the top of front lower wheel well [rocker panel] end cap to. It is not welded to the outer panel. Only the outside edge of the end cap is welded to the flange on the wheel opening.
1951 Fleetline
'50 Styleline DeLuxe 4 DOOR SEDAN (Mist Green) |
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
02-02-19 05:33 PM - Post#2758853
It separates the lower quarter/rocker area from the interior. It's not welded to the quarter, but the gap is filled with sealer. I made new pieces.
02-02-19 05:41 PM - Post#2758856
In response to tommy49
Nice work
z28summit
Reg: 06-11-14
02-02-19 06:34 PM - Post#2758860
In response to RAM_51
Okay, thanks for all the info. Thanks for the pictures and the template! It helps immensely for a first timer to see what you guys have done.
Looks like I have a couple pieces to fabricate, and my fender well.
Any tips on ways to line up the front quarter correctly when the inner and outer rocker aren't straight? Mine seems to have come in contact with something and were bent, tore and twisted; as well as the quarter.
Edited by z28summit on 02-02-19 06:35 PM. Reason for edit: No reason given.
RAM_51
Reg: 12-28-02
02-02-19 06:54 PM - Post#2758861
How much of your wheel house is there?
1951 Fleetline
z28summit
Reg: 06-11-14
02-02-19 07:15 PM - Post#2758863
Its all there from what I can tell at this point and pretty solid. Its bent in a bit at the bottom but I can straighten it. I am leery about cutting to much away before I know the steps/sequence to repair this correctly
Edited by z28summit on 02-02-19 07:18 PM. Reason for edit: No reason given.
RAM_51
Reg: 12-28-02
02-02-19 07:22 PM - Post#2758864
It doesn't look too bad where it counts...namely the upper portion. Looks like the trailing end might need some work. This is a photo of the center section dropped out and being reconstructed. The lower image will give you an idea of how it looks in a pristine state. Also both photos are the left side.
1951 Fleetline
z28summit
Reg: 06-11-14
02-02-19 07:45 PM - Post#2758868
I think mine is good. I dont see any damage to it up top.
tommy49
Reg: 09-28-12
02-03-19 05:39 AM - Post#2758877
When you start peeling away the rot is when you start seeing the extent the repairs will be. I found cover panels, galvanized tin, window screen, and pop rivets, topped off with gallons of bondo.
johnwd98
Loc: Little Falls, MN
Reg: 09-05-10
02-03-19 06:35 AM - Post#2758883
When fixing the rust on my Fleetline, I could see no purpose to rebuilding the part circled in your pic. I did run the drain hose from the quarter window trough out through the inner rocker panel. Otherwise it seemed to drain into the lower quarter, and without good drainage from there I thought the water would just sit in the lower quarter and rocker panel.
1950 Fleetline, 350 TBI, 700R4, 3.73 posi rear Blazer axle, MII front. Remote door and trunk locks, GM cruise control, A/C, |
