Username Post: new diagnostic tool        (Topic#355020)
george88gta
george88gta
Loc: new york
Reg: 04-23-03
01-29-19 04:09 PM - Post#2758504
My old Tech II is not able to keep up with my two newer vehicles ( 2014 Sierra and a 2015 Colorado).
Looking for a reasonably priced ( hobbyist grade tool), preferably for all domestic makes, tool or pc based setup. Any recommendations?
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
01-29-19 06:32 PM - Post#2758526
    In response to george88gta
I have this and use it every day. https://www.autoenginuity.com/ Good coverage and data. It also has "some" programing capabilities. I bought it loaded with domestic and Asian, skipped European so I have an excuse not to work on them. Updates are cheap as well.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
01-30-19 05:35 AM - Post#2758542
    In response to junkman104
just a question, if I read that correctly you buy a tool and if you have lets say a GM, FORD and CHRYSLER, you need the
$250 tool
and
three software packs?
FORD $200
GM $230
CHRYSLER $230
TOTAL $910
or the bundle for $800
https://www.autoenginuity.com/product/domestic-sca...
Edited by grumpyvette on 01-30-19 05:46 AM. Reason for edit: No reason given.
george88gta
george88gta
Loc: new york
Reg: 04-23-03
01-30-19 11:40 AM - Post#2758566
    In response to grumpyvette
I agree grumpy. That sounds like a lot of money for an occasional/hobby use.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
01-30-19 12:41 PM - Post#2758573
if you purchase a ZR13 auto code scanner, from HF,
you need this info
DOWN-LOAD AND PRINT IT OUT!
both work,
https://manuals.harborfreight.com/manuals/63000-63...
OR
https://www.walmart.com/ip/BlueDriver-Bluetoo th-Pr...
https://www.amazon.com/Bluetooth-Adapter-Wir eless-...
Edited by grumpyvette on 01-30-19 04:05 PM. Reason for edit: No reason given.
george88gta
george88gta
Loc: new york
Reg: 04-23-03
01-30-19 01:10 PM - Post#2758577
I like the Blue Driver, but my phone isnt compatible.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
01-30-19 04:05 PM - Post#2758593
george88gta
george88gta
Loc: new york
Reg: 04-23-03
01-30-19 04:42 PM - Post#2758599
So I can plug this adapter into my windows 10 laptop and it will connect to the blue driver device? I like it! Much easier to read the big screen.
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
01-30-19 06:21 PM - Post#2758609
Must have been a Chinese tech II if you are bitcjin about the price. There is a difference between a diagnostic tool and a code reader. I miss understood.
george88gta
george88gta
Loc: new york
Reg: 04-23-03
02-02-19 05:54 AM - Post#2758809
  • grumpyvette Said:
I ordered the Bluedriver and the Bluetooth adapter. Installed the adapter on my PC, but couldn't get the APP to load. Contacted Blue Driver and they told me that this setup won't work. I would need to obtain an android emulator. So options are to return the Bluedriver or load an emulator. The blue driver tech stated that they wouldnt be able to provide much support if I go the emulator route. I found several emulators so I will do some research to see if they really work well.
george88gta
george88gta
Loc: new york
Reg: 04-23-03
02-03-19 06:31 AM - Post#2758876
Just to close this thread, I tried a couple of PC android emulators and was less than pleased. Finally, I decided to return the blue driver and wait until I upgrade my phone or get a standalone device. Thanks for the advice.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
02-03-19 07:05 AM - Post#2758880
thank you for posting your experiences, as its sure to help others,
I would point out that many people won,t deal with that,
as a good many phones and cars are blue tooth linked.
I have several friends now that are using that bluedriver and are happy
Edited by grumpyvette on 02-03-19 07:10 AM. Reason for edit: No reason given.
02-17-19 03:49 PM - Post#2760129
In case someone has a Dodge, Chrysler, Ram, or Jeep, I found this interesting. Features to turn on/off programming.
https://appcar-diagfca.com/en/supported-vehicles /
Airlifter
Airlifter
Reg: 06-07-15
03-24-19 04:47 PM - Post#2762790
Just bought the bluedriver and it found the problem on the bride's 98 Volvo and also read the past codes and gave me all the service bulletins on my 11 F150. So far I am impressed. btw have the cheapest Android that Verizon offers.
1951 styline deluxe sport coupe w/'60 261 engine & 54 powerglide
01-07-20 03:19 PM - Post#2783939
    In response to Airlifter
The pic uploaded sideways. I received an FX2000 for Christmas. I'm like wow!! It's nice. I think it's a low level professional scanner. On my first use, I was able to use it on a 2013 Focus. It would not start. Well, the battery was toast. It looked like a small ball. Fixed that first. Next, it wouldn't not run for long. Dash said 34 miles to empty. Yea, right. Not on a gauge with 150k miles on it. It was reading wrong. So we have to get 4 gallons of fuel. Finally, we get it started. Since a fuel pressure code was present, I used the scanner to check output. It dipped from ~300 PSI to 230 PSI. Knowing F3rd uses cam driven high pressure fuel pumps, I suspected an idle miss causing the dip. Sure enough, #3 plug on a 4 cylinder motor was full of oil. No one for miles had Motorcraft replacements. I clean them off and installed them. The car ran flawless.
Other sensors can be graphed as well. The new scanner will save a lot of time of guessing and use a voltmeter. For now, I do recommend the scanner over basic ODBII scanners. Included are transmission, air bag, CAN, ABS, and other special manufacturer readings. For an Amazon price, it's really hard to beat!
Attachment: graph.jpg (89.64 KB) 11 View(s)
High pressure fuel pump graph.
Execution time: 0.995 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:32 AM
