Username Post: Standard Heater wiring        (Topic#354999)
57210sportsedan
Loc: Germany / Georgia (US)
Reg: 02-06-03
01-28-19 10:52 AM - Post#2758392
Hi All,
I have a low-optioned 210 that came with the full wiring harness and fuse block. I would like to hook up my standard heater per 1957, (which before anyone comments doesn't show up in ANY factory wiring schematic), and I was wondering if anyone out there can tell me how that once was. There is a 5-wire plug that seems to be for the deluxe heater. The dark blue wire in this plug goes directly to the fused "heater" connection on the fuse block. Sounds like a winner, right? Plug one switch wire here, the other to the blower ...
BUT the brown wire coming from the blower motor goes into a three prong plug (the other two slots being empty). This wire has been spliced at one point so I am not 100% sure ... maybe the plug isn't original to this car as plugging it into the only slot it would fit (the orange wire of the three prong AC plug) would bypass the switch of course.
Any takers? Thanks!
Markus
Markus
57 Chevy 210 Sport Sedan
70 Triumph Spitfire
bought and sold a few more ...
01-28-19 12:23 PM - Post#2758398
    In response to 57210sportsedan
A standard recirculating heater has a different wiring harness from the delux heater. The delux heater has a bank of speed control resistors in the heater box. The standard heater has a speed control resistor on the switch. To connect the standard, connect the brown heater wire directly to the switch and the blue wire from the fuse directly to the switch.
Here's the delux resistors. Link to delux heater.
57210sportsedan
Reg: 02-06-03
01-28-19 12:48 PM - Post#2758401
    In response to acardon
Thanks, that is what I was planning but wanted to be sure. The harness is definitely original to the car. I don't know if St. Louis put the "deluxe" harness in all 210's but I was the first person to tinker with it. Unfortunately that was almost 40 years ago and I can't remember this detail.
Markus
70 Triumph Spitfire
Execution time: 0.092 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:20 PM
