Username Post: 400 ci Water Pump/Power Steering Bracket Help        (Topic#354941)
Mr Gee
Loc: Vegas-Come for Vacation, ...
Reg: 05-21-01
01-23-19 08:45 AM - Post#2758007
I put a 400 small block from a 75/76 Caprice in my 61 Impala. The 61 had power steering however the power steering bracket on the 400 was not completely bolted in and not in use at the time of the install. All of the aftermarket power steering brackets available use two lower bolt holes on drivers side of the block, however this 400 engine does not have the bolt holes. Anybody else who has this engine use a different setup and/or different water pump and bracket?
'61 Impala Convertible - Driver
Execution time: 0.191 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:38 PM
