Username Post: No Rockauto Warranty        (Topic#354926)
fuzz1957
Loc: NE IA
01-21-19 01:54 PM - Post#2757892
Buyer beware when buying a Denso oxygen sensor from Rockauto. They consider it a “wear part” and will not warranty it at all. Other parts stores around here warranty the same sensor for a year. I bought one from them five months ago and they won’t do anything - “wear part”. Learned my lesson. From now on I’ll pay a little more and deal with someone I can look in the eye. Read all the fine print if you buy from them. If you don’t, it may cost you.
Fuzz
MAGA
01-21-19 05:15 PM - Post#2757906
    In response to fuzz1957
In a way they could be right. Coolant leaks can damage the sensor as well as too rich a fuel mixture and some fuel additives. I am not agreeing with their policy but I can see their thinking.
IgnitionMan
Reg: 04-15-05
01-21-19 07:40 PM - Post#2757918
Does that Denso sensor have a warrantee offered for that product? If so, Denso would be the people to contact, not Rock Auto.
TAT_2
"18th Year" Silver Supporting Member, and Official CT Grim Reaper
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
01-22-19 03:14 PM - Post#2757962
    In response to IgnitionMan
https://www.sixityauto.com/pub/media/downloads/D en...
PHONE # ON THE BOTTOM
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
aghaga
aghaga
Loc: Altavista, Va.
Reg: 07-05-08
01-24-19 06:02 AM - Post#2758096
    In response to TAT_2
On the Denso warranty link above:
Excluded
from this warranty are Products which are subject to normal wear and tear, such as filters, ignition
wires,
oxygen sensors, spark plugs, wiper blades, etc.
01-24-19 07:44 PM - Post#2758153
    In response to aghaga
Many electrical components don't have much of a warranty and haven't for some time.
That said, there should be a difference between a part that's defective in the box vs. one that works but not very long. Not that not working long is good either, but never working with no relief just sucks.
paulo57509
Loc: Tracy, CA
Reg: 07-18-00
02-26-19 06:35 PM - Post#2760886
FWIW...
"DENSO Warranty Information:
12 months on A/C Evaporator Cores, A/C Compressors, A/C Compressor Clutches, A/C Condensers, Radiators, Fuel Injectors, Fuel Pumps, Fuel Tank Sending Units, Ignition Coils (COP), Alternators, Starters, and Mass Air Flow Sensors. Parts subject to normal wear and tear are not covered (Filters, Ignition Wires, Oxygen Sensors, Spark Plugs, Wiper Blades, etc.). IMPORTANT A/C COMPRESSOR WARRANTY NOTE: In order to ensure that proper warranty credit is issued if needed, the compressor installation instructions must be adhered to. All compressors returned for defect must show proof of purchase of an A/C Orifice Tube (or A/C Expansion Valve), A/C Receiver Drier/Accumulator, and A/C System Flush or a Work Order showing the purchase of these items and that the system was flushed."
https://www.rockauto.com/en/moreinfo.php?pk=160660...
Edit: Beat me to it...
1987 IROC-Z 5.0L
1992 Lumina Euro 3.1L
2003 GMC Safari
Edited by paulo57509 on 02-26-19 06:36 PM. Reason for edit: No reason given.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
02-27-19 12:13 PM - Post#2760939
    In response to paulo57509
you posted the same baseless CRAP in a duplicate thread
NO VENDOR ANYWHERE will warrant an oxygen sensor youve used for 5 months , rockauto and any other vendor is well within their rights and any reasonable persons expectations
very few companys warrantee any sensor or electrical component once its been installed,
simply because they have zero control over the install or running conditions.
certainly most will not past 30 days ,
I,ve purchased thousands of dollars of parts from rockauto
service is fairly fast, and provided you read carefully and don,t shop using the ;lowest price option you generally get decent value.
under the conditions and time frame stated I don,t think they are being unreasonable.
a leaking fuel injector, improper installation, a leaking head gasket oil or coolant contamination, detonation, improper fuel pressure use of E85 (ethanol) and several other factors will kill any oxygen sensor in a very short time
2blu52
2blu52
Reg: 03-12-02
03-07-19 10:33 AM - Post#2761530
    In response to grumpyvette
When I worked a parts counter a number of years ago we would not even take a part back if it was removed from the box. That applied to electrical only.
THOMAS JEFFERSON
Execution time: 0.126 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:53 PM
