Username Post: Tore down...        (Topic#354911)
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-19-19 07:13 PM - Post#2757765
I took the standard steering column out of the ramp truck which is a three on the tree and broke it down cleaned it good and put it all back together and greased all the area's I thought needed it. Should be good as new.
I also found out that a standard 3 on the tree turn signal switch is the same one used for a tilt wheel four speed.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Execution time: 0.119 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:30 PM
