Username Post: Stock air cleaner to hood clearance?        (Topic#354910)
Beltfed
Reg: 10-04-18
01-19-19 05:43 PM - Post#2757762
In searching for answers to an air cleaner question below I keep seeing hood clearance issues which concerns me. Does anyone know how much clearance there is when using a stock air cleaner and a Carter 4bbl on a 57 Bel Air?
TR56210
Reg: 10-28-18
01-19-19 07:41 PM - Post#2757767
    In response to Beltfed
I searched back for the posts you referring to without success.
You are replacing a four barrel carb for the NOS carter you reference and you have resolved the 4.5 to 5 spacer issue. So, measuring the height of the old carb to new, my bet is they are identical, won’t that answer your question?
Beltfed
Reg: 10-04-18
01-19-19 08:32 PM - Post#2757770
    In response to TR56210
Unfortunately no. The car, a freebie, came with a 2 bbl carb. I am told the car codes to be a 283 with a 4 bbl. (engine stamped T1121FC). When and where it got changed is lost to history.
WagonMan
WagonMan
Loc: Las Vegas, NV
Reg: 10-26-04
01-21-19 01:09 PM - Post#2757885
I would say from my experience, there is about enough room for the oil cap between the hood and air cleaner. When I got my 57, the undercoating on the underside had the "OIL" imprint in it from someone previously forgetting to reinstall the oil cap when they closed the hood. The hood was not dented in this area from this happening.
Charles
57 210 4dr. Wagon(bought '82)
-350/700r4 Mild Custom
56 BA 4dr. ht.(bought '98)
-265/TH350 Mostly Stock
29 Ford Sedan(bought '75)
-4.3L/TH350(in progress)
57tim
57tim
Loc: Cameron, Wi, USA
Reg: 11-09-01
01-21-19 08:20 PM - Post#2757920
I used to run a 4 barrel(modified for power)in the summer and then run a 2brl and intake for economy in the winter. Gas was $.25 per gallon.
57 Bel Air 2dr Ht
327 700r4
Execution time: 0.098 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:00 AM
