Username Post: Camber angle        (Topic#354908)
Mick53
Mick53
Loc: Northern Indiana
Reg: 04-02-16
01-19-19 02:33 PM - Post#2757747
I'm having front straight axle on my 53 1/2 ton pickup altered along with 57 Bel Air 2" drop spindles so I can put my 12.88" Wilwood disk brakes on it. This will be a driver and strip for fun (that's the best way). I will be running an 8" wide tall tire. I believe the blown 292 weighs less than the 235 even with the 4-71 blower. I have done some searching and some say positive and some say negative angle. Thank you for your time and advice.
01-19-19 02:43 PM - Post#2757749
    In response to Mick53
More important is the caster angle for directional stability, camber close to zero should be ok for fixed suspensions. Try and get at least 3 degrees positive caster.
Bel Air kiwi
DECEASED
Bel Air kiwi
Reg: 04-24-14
01-23-19 09:17 PM - Post#2758078
Hi Mick, The 292 isn't a lot lighter than the old 235. It may be a touch, but it is about the same as a SBC.
Rember this is a unique block from its sibling 230/250 designs. In part, this is because it has a much taller deck height, but it also may be a more solid design as it was always going in vans and pickups.
I don't have a 471 blower but picking up a 671 is not for the weak or frail.
I wouldn't be surprised if your blown 292 wasn't just a little bit heavier than stock.
Cheers Kiwi
Mick53
Mick53
Reg: 04-02-16
01-23-19 10:09 PM - Post#2758085
    In response to Bel Air kiwi
I guess I was thinking about the 250. I hadn't thought about the taller deck on the 292. I did receive my wireless wheel scales today so when I finally get home in a couple of weeks I may have to weigh it. I have been working 550 miles from home for 6 months and not been able to work on my truck. I'm going to take the rest of the year off and hope to run drag week this fall. Thank you. I have a super special part coming from down your way maybe next month but can't talk about it yet. Going to be a game changer. Thank you for your time. I'm going to try to get down there next winter. You guys do some crazy stuff with 6's down there.
Execution time: 0.107 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:18 PM
