Username Post: Change over to paper air filter tips?        (Topic#354901)
Beltfed
Reg: 10-04-18
01-19-19 08:13 AM - Post#2757720
Want to change the ‘spaceship’ oil filter over to a paper or foam type. Have no idea what size filter nor what needs to be done to accomplish this. Reason: I don’t have the insides or oil bath and a PO modified the lower housing fit a later carb.
The major suppliers don’t seem to address this issue in their catalogs unless I missed it. 1957 283 c.i. with Carter 4bbl. (4-7/32”). Thanks.
Edited by Beltfed on 01-19-19 08:18 AM. Reason for edit: No reason given.
57tim
57tim
Loc: Cameron, Wi, USA
Reg: 11-09-01
01-19-19 11:24 AM - Post#2757739
    In response to Beltfed
Probably have to clean it up and go to a parts store that will take the time to dig through their supply and trial fit the elements until one fits. JMHO
57 Bel Air 2dr Ht
327 700r4
Beltfed
Reg: 10-04-18
01-19-19 02:53 PM - Post#2757752
    In response to 57tim
We do that same thing with radiator hoses when we drop a non stock motor into a engine bay. I’ve cut sections out of some pricey rubber to get what I need. I guess I’m off to my FLAPS.
craig32
Loc: PA
Reg: 08-05-07
01-19-19 03:32 PM - Post#2757755
Are you trying to keep the original cleaner and just retro fit a modern element, or just want a paper filter setup? You can get aftermarket chrome air cleaners, like Mr. Gasket, but you'll need an adaptor for the WCFB. If you go this route, use the plastic adaptor for a template to make a metal one, as the first time it backfires, the plastic one will melt!
Beltfed
Reg: 10-04-18
01-19-19 04:16 PM - Post#2757761
    In response to craig32
What I’m trying to do is keep the original outside looks of the air cleaner while upgrading to a paper element. I don’t have the insides and the carb hole has been enlarged to 5”. I have reworked a plastic adapter for a pattern. I see no options other than a paper/foam air filter for the inside.
I would think many tri-five owners have made this changeover much like the spin on oil filter.
Edited by Beltfed on 01-19-19 04:17 PM. Reason for edit: No reason given.
Lee T
Reg: 07-05-12
01-20-19 11:10 PM - Post#2757840
https://www.classicchevy.com/chevy-oil-bath-elemen ...
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
01-21-19 03:45 PM - Post#2757900
i think ecklers has one listed that will fit right in the original housing.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
15 chevy equinox
Lee T
Reg: 07-05-12
01-22-19 12:22 AM - Post#2757933
    In response to 62chevy427
Yes, that is the one in the link I posted.
Replacement Filter
Fits 1957-58 2 & 4-Barrel Air Cleaners
Replaces Original Oil Bath Element
Jalapeno
Jalapeno
Loc: The Republic of Texas
Reg: 04-30-00
01-23-19 07:19 AM - Post#2758002
1957 4 bbl:
K&N E-3630
STP AF5HD
WIX 42050
Purolator A30005 (the A30067 is just about 1/8" too short. A small gasket or thin weatherstrip will make it fit)
Fram CA-1 or CA-151
Hastings AF5
Car Quest 87050 above 053007T2
Jalapeno
Beltfed
Reg: 10-04-18
01-23-19 05:17 PM - Post#2758053
    In response to Jalapeno
Thanks much guys. I will visit my FLAPS in the next couple of days with the above information. Got talked into help pulling the engine out of a 64 Chevy truck today and more tomorrow by my nephew. I jump at any chance to help the next generation learn to love and work on vehicles with carburetors.
Bone stock except for dual master cylinder.
Edited by Beltfed on 01-23-19 05:18 PM. Reason for edit: No reason given.
Execution time: 0.113 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:57 PM
