Username Post: 56’ Bel Air Tranny Swap        (Topic#354872)
CRIZROCK56
Reg: 01-16-19
01-16-19 10:25 AM - Post#2757543
Hi , I removed the Powerglide from behind a 265 in my ‘56 BelAir . I replaced it with a TH350 I am attempting to mount a newer starter but it will not bolt to the block . The adapter plate I removed from power glide does not mount to TH350!. What’s the best way to mount starter .also can I use same tranny lines ? Thank You .
BUDDY HOLLY LIVES !
Edited by CRIZROCK56 on 01-16-19 10:30 AM. Reason for edit: No reason given.
01-16-19 12:21 PM - Post#2757547
    In response to CRIZROCK56
Starter adapter: Link
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
01-16-19 01:11 PM - Post#2757550
    In response to acardon
You ALSO need either a rear crossmember/trans mount OR an aftermarket mount kit to side mount the TH350 transmission to the stock frame mounts/horns. If you're keeping the column shifter, you'll need the detent display for the dash and the linkage kit to connect to the transmission shift lever. Your transmission cooler will work, but you'll need to rebend the hard lines to fit. I am Butch/56sedandelivery.
CRIZROCK56
Reg: 01-16-19
01-16-19 01:14 PM - Post#2757551
Thank You . yes i purchased the column shift rod kit from lokar and used a rear crossmember mount. Glad to here transmission cooler will work > I noticed on one of the original tranny lines there was a one way valve . Do I leave this brass check valve on?
CRIZROCK56
Reg: 01-16-19
01-16-19 01:15 PM - Post#2757552
Thank you
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
01-17-19 09:43 AM - Post#2757603
That valve is probably something a PO installed to try to keep the Powerglide from "burping"; purging fluid after they sit a while through the fill tube. I'd delete it for the TH-350. I am Butch/56sedandelivery.
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
01-17-19 02:34 PM - Post#2757623
if you are still using the front motor mounts you will also need the side mount kit (i got one from ecklers) to keep the motor from twisting. long time ago i tried chaining one to the frame on both sides and it bent the front motor mounts. 265 does not have bolt holes for frame side mounts.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
15 chevy equinox
CRIZROCK56
Reg: 01-16-19
01-17-19 03:07 PM - Post#2757626
    In response to 62chevy427
So what your saying is the front engine mounts and the rear crossmember for the transmission is not enough ?
Thank you
Member #409
01-17-19 07:02 PM - Post#2757645
With a 265 or 57 283, you need aftermarket rear mounts that replace your stock rear mounts. A crossmember under the rear of the transmission by itself is unacceptable, it allows the engine/trans to "roll over" on the mounts too easily, as they are not far enough apart. If you wish you can run a crossmember too, but you must have the bellhousing mounts.
These mounts are attached by the transmission to engine bolts at the bellhousing.
For your starter, you need the aftermarket starter adapter plate that goes between the transmission and engine.
CRIZROCK56
Reg: 01-16-19
01-18-19 09:52 AM - Post#2757670
    In response to Rick_L
OK I understand . Thank You for the informations guys .
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
01-18-19 07:34 PM - Post#2757703
My next door neighbor has a 56, 210, 4 door sedan he inherited from his Father. Has a 350 engine that's front mounted with stock mounts, and a TH-350 transmission that has the aftermarket, side mount transmission kit. He does not have a rear crossmember; the transmission just "hangs" out there, like the stock transmissions do. It has been this way for many years, but I personally would not do it this way. I've also know guys who kept the stock front engine mounts, later automatic transmission, and a rear crossmember/trans mount. I would't do it that way either. Side mounting the engine (can't be done with 55-57 blocks however), and using a rear transmission mount/crossmember is the best way. Next best way would be a 3 point mounting; stock front engine mounts, aftermarket side mount transmission kit, and a rear trans mount/crossmember. My Pro Bracket 56 Chevrolet I ran in the late 70's/early 80's had a BBC, Chevy II aluminum Powerglide, and a Camaro 12 bolt rearend. The engine was mounted with a Hurst saddle mount at the front, and a rear trans mount/crossmember at the rear. The wide stance of the Hurst saddle mount prevented engine torque-over. Never had any problem with the long distance between engine-trans mounting; even with the Chevy II Powerglide with the 4, 3" cooling holes, in the bellhousing. Course everyone said I'd break the bellhousing; never happened. You could probably come up with a way to prevent engine torque-over using stock front mounts (chain, metal bracing, etc), but it would probably be noisy and transmit engine vibration. Then you could use just a rear trans mount/crossmember. I am Butch/56sedandelivery.
Member #409
01-19-19 08:00 AM - Post#2757718
By my count that's a 5 point mount.
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
01-21-19 03:54 PM - Post#2757904
yes. been there,tried that. the front original motor mounts are not far enough apart,like side mounts, to keep the motor from twisting. i tried it on a 55 and i think the only thing that kept it from moving more was the exhaust. the bottom of the engine must have moved 2 or 3 inches.
95 impala (new)
15 chevy equinox
60chev
60chev
Loc: Rotchester, NY
Reg: 01-24-09
02-05-19 10:37 AM - Post#2759110
I've never had a problem with the original front mounts on any of my 57 Chevys. Had 4 so far with late model trans swaps. One with th400, one with 2004r, one with 700r4 and one with th350. All home made cross members too for trans mount. I am hard on my cars doing burnouts and such and i occasionally race my current 57 with this set-up. Daily driven with lots of miles on my cars. Never broke or twisted anything. So there's first hand experience with several trans swaps. Just sayin'........
60chev
1957 Bel-Air 4-door 327/th400
1979 C20 350/4speed
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
03-18-19 06:26 PM - Post#2762428
    In response to 60chev
i assume you are using side mounts on the transmission.
95 impala (new)
15 chevy equinox
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
03-18-19 10:02 PM - Post#2762442
The stock starter motor you had on the original cast iron Powerglide will be needed with the starter motor adapter ring kit. I am Butch/56sedandelivery.
557B2100
557B2100
Reg: 06-02-13
04-01-19 08:42 AM - Post#2763392
With your set-up in addition to the starter adapter plate, you need a Turbo Mount Kit and transmission crossmember mount.
Edited by 557B2100 on 04-01-19 08:45 AM. Reason for edit: No reason given.
Execution time: 0.155 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:50 AM
