Username Post: 1990 Celebrity Torque Converter        (Topic#354845)
Turbo2
Reg: 07-26-16
01-14-19 02:06 PM - Post#2757360
What would make the torque converter on my 1990 Celebrity Eurosport Wagon with the 3.1 V6 kick in when it's in drive (not OD) and only doing about 35 MPH?
It makes the whole car vibrate.
01-14-19 07:41 PM - Post#2757389
    In response to Turbo2
There was a tech bulletin back in the day to update the prom to facilitate a later lock up point. Also check your tps function, this can cause this issue also.
Turbo2
Reg: 07-26-16
01-17-19 07:13 AM - Post#2757588
Can I check the TPS with an Ohm meter?
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
01-17-19 07:03 PM - Post#2757641
Try this https://easyautodiagnosti cs.com/gm/3.1L-3.4L/how-to-test-the-thrott le-position-sensor-1
Turbo2
Reg: 07-26-16
01-18-19 07:03 AM - Post#2757657
    In response to junkman104
I just noticed that this is only happening when the car is fully warmed up. When it is cold, it works fine.
Turbo2
Reg: 07-26-16
02-05-19 05:47 PM - Post#2759145
Well, I was getting some funky readings from the TPS so I changed it. For about half the day it was running the best it has run in a decade, but the SES light would come on every time I use the gas pedal (SES was never on with the old TPS). If I let it idle or just coast down the road it would go out. Just now on my way home it went right back to locking the torque converter up at 35 MPH in drive.
02-05-19 07:18 PM - Post#2759152
Scan it for the code.
Turbo2
Reg: 07-26-16
02-07-19 05:59 AM - Post#2759273
It has a code 22 TPS low voltage. I removed and reinstalled to make sure it was in correctly. I tested it with my multimeter and all readings are within spec but every time I press the gas pedal the SES light comes back on.
02-08-19 11:16 AM - Post#2759393
Make sure you have 5v reference signal and about .5 volts at hot idle.
Turbo2
Reg: 07-26-16
02-21-19 08:49 AM - Post#2760413
It checked out that it was all in spec so I bought another TPS from a different company and it's working great. A few days later the IAC started to act up with a low idle and even stalling a couple of times. I replaced the IAC and went through the procedure to reset it 3 times, but the sensor still isn't working correctly. When I start it up cold it idles a little high as it should but then instead of backing down the RPM's start increasing. Is this another bad sensor right out of the box, or am I missing something?
02-23-19 08:42 AM - Post#2760556
Is the tps adjusted to .5v at base idle?
Turbo2
Reg: 07-26-16
02-24-19 06:55 AM - Post#2760624
Unlike the GM 3.8l the 3.1l doesn't appear to have any adjustment for it.
02-24-19 06:58 AM - Post#2760625
Still, get a dvom on it and see what you have.
Turbo2
Reg: 07-26-16
03-16-19 04:10 PM - Post#2762257
All voltages were in spec again so I replaced the IAC again. The new IAC would not reset at all, it would idle super high all the time. I replaced it again and now everything is finally working like it should. It's unbelievable what we've come to, 2 original sensors last 30 years but brand new ones are junk right out of the box.
03-17-19 03:05 PM - Post#2762311
Great, you stuck with it!
Execution time: 0.123 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:48 PM
