Username Post: Hood Spring Removal        (Topic#354821)
Old Chevy Soldier
Old Chevy Soldier
Loc: Central Montana
Reg: 03-12-12
01-12-19 04:10 PM - Post#2757216
I remember seeing a homemade spring removal tool on this forum. It was a safe way to remove these springs. I tried the stickies and a search with no luck. If anyone remembers where this was posted, please let me know. Might make a handy sticky. Thank You, Tim
Life is to short to ride an ugly horse or drive a Ford
01-13-19 11:39 AM - Post#2757271
    In response to Old Chevy Soldier
http://chevy.oldcarmanualproject.com/miscellaneous...
http://www.youtube.com/watch?v=P9jc8E0aN3k (Spring on tool) Bob Hayden
http://www.youtube.com/watch?v=c9DHUHLoKwA (Spring on car) Bob Hayden
Don't remember if this will work for our years.
29-41, 42-48, 49-54 Moderator
ruscar
Loc: GA
Reg: 12-22-06
01-13-19 02:27 PM - Post#2757283
Please note, that tool is for 1949-1954 hinge springs only.
Russell
Old Chevy Soldier
Old Chevy Soldier
Reg: 03-12-12
01-13-19 04:20 PM - Post#2757290
Thank you Keith. Ruscar, I think this will work on the 41-48 cars also. The only difference I can see is that 41-48 springs are inverted. I'll let you know how it works out.
Thanks again, Tim
Broo102
Broo102
Loc: Huntington Beach, CA.
Reg: 09-30-14
01-14-19 12:08 AM - Post#2757312
Ive always inserted (wiggled) some washers, one at a time to spread the spring then it comes off pretty easy
Thanks!
Bru
John 3:16
32 Chev. 5 Win. Sports Coupe
Old Chevy Soldier
Old Chevy Soldier
Reg: 03-12-12
02-03-19 10:57 AM - Post#2758891
    In response to Broo102
Update:
I removed the front clip with the hood still attached to the car. With the hood propped up, I was able to manually pull the bottom of the hinge spring down and forward. With the hood propped all the way up, it wasn't difficult to put a screwdriver across the spring hook, grab each side of the screwdriver and pull down. Easy-peasy. Tim
Jack Crain
Loc: Wichita Falls, Texas
Reg: 07-24-11
06-25-19 10:20 AM - Post#2769224
I don't know, but pulling the front off just to pop the hood springs off sure seems like a bit of overkill to me. But every one has their own methods I guess.
1946 Fleetmaster 4-dr Sedan with '57 235
Fenton Dual Exhaust and Intake
Dual Carter Webbers 2 barrel Carbs
HEI ignition
Front Disk Brake
T-5 Tranny
Execution time: 0.105 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:27 AM
