Username Post: 57 air cleaner fitup issues.        (Topic#354818)
Beltfed
Reg: 10-04-18
01-12-19 11:34 AM - Post#2757200
Have sourced an almost new 4bbl Carter carb. Tag attached says it’s built for a 1956. Sourced a very nice 1957 air cleaner. Problem is...the two don’t fit together. The carb diameter is 4.5” while the inside bottom opening of the air cleaner is 5”. Plus there is no way the cleaner with sit on the carb. It looks to me as if I’m missing something like a velocity stack/adaptor or I’ve got wrong parts. Any helps guys?
Beltfed
Reg: 10-04-18
01-13-19 05:30 PM - Post#2757300
    In response to Beltfed
After a lot of poking around on the internet I think I may have a solution. The bottom half of the air filter housing is made or has been adapted to a modern carb like Edelbrock or Holly with a larger air horn. I have the original style Carter which has a smaller air horn.
Have seen several plastic adapters on several sites. Didn’t want plastic. O’Brien Truckers has an aluminum one on their site. Fits 4-7/32” air horn to 5-1/8” filter opening. It’s more expensive than plastic but who’s worried about money in this hobby. Thanks.
notcamero
Reg: 08-02-03
01-13-19 05:53 PM - Post#2757301
Is that an oil bath air cleaner? Seems odd that it would be made for the later model carbs if so.
Beltfed
Reg: 10-04-18
01-13-19 07:56 PM - Post#2757307
    In response to notcamero
I believe it is the oil bath type. StampEd into the metal is ‘front’ as read from the outside. Below ‘front’ is stamped ‘oil level’ as read from the inside. I’ve been around hot rods most of my ‘car life’ and guys with their imagination know no bounds.
This is my second build back to original car. My first, a 1938 Lincoln Zephyr three window coupe, has been on jack stands for 5 years while I chase rare parts.
Edited by Beltfed on 01-13-19 08:08 PM. Reason for edit: No reason given.
Rustchips
Rustchips
Loc: DFW Texas
Reg: 02-24-05
01-14-19 11:31 AM - Post#2757348
Those Zephyr's are good looking coupes.
Cleon
1928 Chevy Coupe
1955 Chevy Bel Air HTP
1970 El Camino
1990 F##d Mustang Convertible
Execution time: 0.167 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:42 PM
