Username Post: Rochester 1 bbl carbs        (Topic#354811)
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
01-11-19 05:16 PM - Post#2757146
Random GM Rochester 1 bbl carbs, Some of running engines some older rebuilt stock from the 60's $25.00 ea plus shipping.
Attachment: rochester.jpg (39.23 KB) 17 View(s)
Chevs of the 40s
Jeff1951
Loc: Bloomfield Township, MI
Reg: 11-12-18
01-17-19 06:02 PM - Post#2757637
    In response to cbmkr56
Is there any chance that you might have one with the brass tag with part number 7003152? I know it's a long shot but thought I'd ask.
Thanks!
Jeff
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
01-17-19 08:11 PM - Post#2757648
    In response to Jeff1951
I will check in the morning.
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
01-18-19 08:10 AM - Post#2757660
Sorry none there.
Jeff1951
Reg: 11-12-18
01-18-19 01:03 PM - Post#2757678
Thanks for taking the time to check. really appreciated.
Jeff
64K10
64K10
Loc: Cali
Reg: 06-25-04
02-09-19 04:52 PM - Post#2759500
Hi, just checking...
Looking for one and/or two Model B (manual choke type) carbs for the 235ci motor. Bolt spacing is 2-15/16" on the base of the throttle body.
64K10
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
02-10-19 11:05 AM - Post#2759547
    In response to 64K10
Stud type air cleaner ??
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
02-10-19 11:24 AM - Post#2759549
no manual choke models in rochester b, I can look this week for some carter YF 2100's
64K10
64K10
Loc: Cali
Reg: 06-25-04
02-10-19 11:49 AM - Post#2759553
Thank you very much for checking.
Looking for two matching carbs to put on a Thickstun manifold that has studs for the 2-15/16" 235 base carbs.
If the carbs were the BC type (auto choke) I could run those.
I've never fooled around with the Carter YF2100s (manual choke version for the 235 from '53-'56)
but I'm sure they'd work just fine also.
As for the question about the "Stud type air cleaner ?" If you mean the air cleaner support bar at the top of the carb air horn, "no" not a requirement to have it. Since I'll be making my own air cleaner.
64K10
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
02-10-19 01:02 PM - Post#2759559
Here's 2 old stock rebuilt with the wide base.
Attachment: IMG_20190210_135723615-2624x1476-1312x738.jpg (259.25 KB) 4 View(s)
64K10
64K10
Loc: Cali
Reg: 06-25-04
02-13-19 01:50 PM - Post#2759842
CBMKR56,
Carbs arrived today.
Thank you!!!
64K10
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
02-14-19 05:14 PM - Post#2759946
Thank You
Chevs of the 40s
Execution time: 0.07 seconds.   Total Queries: 19   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:55 AM
