Username Post: 700R4 Leaks 241 seems to be full?        (Topic#354807)
ballencd
Loc: Columbus, NC
Reg: 01-09-19
01-11-19 02:28 PM - Post#2757133
My 1991 V1500 Suburban with 350 TBI, 700R4 and 241C just started leaking trans fluid. Didn't look like it was coming from the bell housing so I washed the back of the engine, transmission and transfer case and ran it in the drive.....no leaks. Then I ran it on the road and it leaks quit nicely. Looked like it was coming from the top of the trans, maybe from the transfer case vent line but could not be sure. Opened the transfer case fill plug and it seems to be full as in overfull as tons of fluid came gushing out. Question #1...Can fluid transfer from trans to transfer case? If so, #2 What would I look for to fix it? Thanks
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
01-12-19 04:36 AM - Post#2757176
    In response to ballencd
Question #1 yes
Question #2 transfer case input seal. Means remove the transfer case and replace the seal.
ballencd
Loc: Columbus, NC
Reg: 01-09-19
01-12-19 07:26 AM - Post#2757180
    In response to junkman104
Thank you for the response. I guess its time for me to learn how to do that. I replaced the rear transfer case seal in my 88 Suburban a few years ago and it wasn't hard. Anything I should look specifically for other then any damage to the shaft?
Thanks again
Charlie
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
01-13-19 05:27 AM - Post#2757249
Nope that is about it, the 241 has a bearing retainer that holds the seal and unbolts from the case. Makes putting in a new seal easy.
ballencd
Loc: Columbus, NC
Reg: 01-09-19
01-14-19 09:59 AM - Post#2757330
Do I remove the adaptor with the transfer case or leave it on the transmission?
ballencd
Loc: Columbus, NC
Reg: 01-09-19
01-14-19 12:29 PM - Post#2757347
OK....I got the transfer case out and the space within the adapter was not full of transmission fluid......How can that be???.... the transfer case was overfull, the transmission was low and fluid was blowing out the transfer case vent and there was no fluid (maybe a tablespoons worth dripped out when I separated it).
Any idea where I go from here? I'm thinking that it wouldn't flow out of the adapter into the transfer case sitting in the drive. The rear transmission seal is almost 6" from the transfer case input seal so the oil would have to be in-between them....right?
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
01-14-19 06:12 PM - Post#2757381
Unless someone has the transmission vent connected to the transfercase vent its the only way they would transfer. Do you park on a grade nose up? Level ground here is hard to find.
ballencd
Loc: Columbus, NC
Reg: 01-09-19
01-14-19 07:23 PM - Post#2757386
I don't see a transmission vent at all. I did start the engine with the transfer case out and put it in gear and got a fine stream of ATF out of the transmission seal directly into the adapter.
I am going to replace both the transfer case seal and transmission seal and put it back in. I still don't understand where the fluid went that got sprayed into the void in the adapter when I found it empty when I pulled it apart.....I am so confused.
Senior Chevytalk Moderator
01-15-19 06:52 AM - Post#2757428
ballencd,
Have you taken any pictures? Pictures would be helpful. I've never seen a 241C taken apart.
ballencd
Loc: Columbus, NC
Reg: 01-09-19
01-15-19 04:37 PM - Post#2757488
I thought I had taken several pictures of the front of the 241C but I can not find them! : (
The front of the transfer case had a 4 bolt flange with a double sided seal. The seal had a spring on each side which was different then I have seen before. The flange was simple to remove and simple to press out the old seal because I could get to both sides. I did warm up the flange and freeze the seal to get it started straight on the re-install as it was a very tight fit.
Apparently I have to pay to add pictures to this post so the ones I do have will not get uploaded. Sorry about that.
The transfer case is back in now. I replaced the seal on the input of the transfer case only. I did put some (small amount) silicone sealant around the outside edge of the input flange and another bigger bead on the outside flange of the adapter to transfer case seat. It's filled with ATF and seems to be running fine. I plan on draining the trans and putting in a new filter but didn't want to muddy the waters with my first issue. It was a messy job on a gravel drive but not terribly hard.
It turned out that neither the 350 or 700R4 transmission have output shaft seals in them (at least when configured with a transfer case). The transmission seems to squirt ATF into the adapter to lubricate the speedo gears and then drains back into the transmission. The seal in the front of the transfer case is there to stop ATF swapping between the transfer case and the transmission. In my case the ATF was passing through the adapter and past the transfer case seal and when full it blew out the transfer case vent. Messy.
Thanks for the help.
01-16-19 10:33 AM - Post#2757539
You do not have to pay to post pictures on ChevyTalk. You do have to use a host site if you are not a supporting member of ChevyTalk.
http://www.chevytalk.org/fusionbb/showforum.php?fi... Posting photos by Tony
29-41, 42-48, 49-54 Moderator
Execution time: 0.087 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:59 AM
