Username Post: 93 C1500 5.7 fuel pump or regulator        (Topic#354802)
Sabino
Reg: 07-16-05
01-11-19 08:17 AM - Post#2757108
I measured 8 psi with actron in line adaptor after fuel filter on a 93 5.7 TBI C1500. I have read it should be at least 10psi.
Is there a way to tell if it's pump or regulator? It seems regulator is set by spring so it's active all the time.
background
I replaced the fuel pump about a year ago when replacing the fuel sending unit. I hadn't ordered a fuel pump so just picked up one from Autozone. I didn't replace filter at the time. I meant to drive it a bit and then replace filter but forgot.
Recently, I had some stalling/hesitation/hard shifting and replaced the filter & knock sensor (had transient code on it). Drives well now - but when I measured fuel pressure it's lower than it should be.
I'm trying to decide if I should just drop tank and put in an ACDelco pump or attempt to troubleshoot the pressure regulator. It seems easier to drop tank/replace pump than get into the TBI?
thanks in advance for any advice/suggestions
65 Belair 350
68 Camaro 327
85 Caprice 5.0L
93 Suburban 5.7L TBI
1983G20Van
Loc: Bedford, Texas, USA
Reg: 11-13-02
01-11-19 08:27 AM - Post#2757110
    In response to Sabino
background
The TBI is very easy to get into and the regulator springs tend to corrode and snap in half.
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
01-11-19 09:25 AM - Post#2757114
Autozone's house brand is pretty poor quality. You should either use an AC Delco or Delphi pump. I prefer Delphi but it is now made in China as well so flip a coin. I would change the fuel filter and check again, but I would suspect the pump. 9-13 psi is spec, but a new pump should give you 12-13.
It's personal preference,but I find it way easier to unbolt the bed and slide it back a foot than drop the tank. It's 8 bolts that you can get with an impact and it doesn't matter how much fuel is in the tank. You're also working on the pump at waist level.
Jeff
Sabino
Reg: 07-16-05
01-11-19 06:02 PM - Post#2757149
    In response to bowtie44s
Thanks for replies. I have a Suburban so unfortunately it's a drop of tank.
I'm thinking I'll plan on doing both. It has a bit over 200k miles and I've never touched the TBI. I see there is a gasket kit on RockAuto by ACDelco so it won't hurt to clean it up and replace gaskets, etc. I'll get a pump at the same time and do that right away if the TBI doesn't fix it - and when I get the time if the TBI does fix it.
65 Belair 350
68 Camaro 327
85 Caprice 5.0L
Sabino
Reg: 07-16-05
02-17-19 09:45 AM - Post#2760106
Just follow up on result. I dropped tank and replaced pump with an AC delco. Fuel pressure was then a solid 12psi and didn’t vary with reving engine. This fixed all my drivability issues. No more rough idling, stumble on accelation - and much more overall power! Up shifts/downshifts smoother too! I guess low fuel pressure meant more throttle just to drive normally and it confused computer.
Wow, I feel dumb I let it get this bad before fixing it. It had been getting worse gradually for so long I forgot how it was suppose to drive. I’ll put rebuild of TBI off until weather nicer now.
Thanks for the advice.
65 Belair 350
68 Camaro 327
85 Caprice 5.0L
Execution time: 0.063 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:40 AM
