Username Post: Wheel doesn't want to come off        (Topic#354800)
Bill K.b
Loc: upstate NY
Reg: 10-24-05
01-11-19 05:10 AM - Post#2757101
The 2002 2500, left front wheel. Whanged on it with a big sledge and nothing, it's rusted into place on the hub.
Was thinking about loosening all the nuts and driving down the street swerving hard back and forth and see if that helps. Once it pops I can jack it up and crank the lugs back so I can come back home with it, I got a cordless impact so no big deal there.
The tire is still decent so I don't want to bust a belt in it.
I did hit it with PB Blaster, I probably should go at it with a wire brush to start cleaning it up too.
The right side did come off but it was a bear, took a few whacks from the same hammer, I cleaned the hub up good and coated it with anti-seize before I put it back on.
The biggest problem is I have mismatched brake pads right now. I had a vibration that seemed to be coming from the right front at 65-70 so I went to look what was going on. Nothing obvious except maybe glazed pads, but on the off chance the rotor was warped I swapped it out along with new pads. Figured it wouldn't be hard to get the other side off and do those pads too. Wrong, of course.
Those who can, do. Those who can't, criticize it on the internet.
Driving 2002 Express 2500
2002 Express 2500 extended
1988 G20 conversion
1993 GMC 3500 dually
Plus cars for swap and sale
& yes, I once tried a frame swap on a 51 Chevy.
Whitetail Hunter
"2nd Year" Platinum Supporting Member
Whitetail Hunter
Loc: Green Bay Wisconsin
Reg: 03-28-15
01-11-19 05:30 AM - Post#2757104
    In response to Bill K.b
Not much you can do but keep at it with the oil and hammer. I had a rear one that I used the scissor jack between the springs and wheel. Whaen it finally came off it flew about 3 ft. Slowly spin the wheel and hit the wheel bead. Not hard as to bend the wheel. Just to work that rust around. Like hitting a nail. Put antisieze on everything when done.
Bill K.b
Loc: upstate NY
Reg: 10-24-05
01-11-19 07:06 AM - Post#2757107
    In response to Whitetail Hunter
I did drive it back and forth with about three lugs on and it didn't move a bit. Even pounding the brakes hard. Unfortunately I can't spend a lot of time swinging at it, I paid for that all day yesterday.
I've read a lot of crazy things people have tried, driving over curbs, hitting curbs on purpose, etc.
My G30 years ago the drum was locked on in the back like this and I ended up destroying the drum by cutting around the hub with a cutoff wheel until it was loose. Worst case I could do that again, I don't think another rim is very expensive at the you pick yard.
The big thing once it's off is to clean it up under there.
1988 G20 conversion
wreckmech
Loc: Parsippany, NJ
Reg: 10-08-02
01-11-19 08:25 AM - Post#2757115
I've had this issue a couple of times. I figured out that you can use a 2x4 wedged between the edge of the rim and the frame with the truck on jacks. Start the truck & use the power steering to bust it loose. It's worked every time for me...Good luck
MiragePilot
Loc: Tucson, AZ
Reg: 08-18-16
01-11-19 09:36 AM - Post#2757121
I have read that if you just loosen the lug nuts and then take the vehicle for a (short) drive, it should pop the wheel loose.
I had this issue with my van a few years ago. Wasn't able to get it off by banging on the wheel. So I hit it with a penetrant oil, and tightened up the lug nuts. Drove it shortly thereafter to Sears Auto Center (to get 4 new tires) and told them I was never able to get the wheel off for maintenance earlier, and that they could expect to have problems.
The wheel popped right off for them!!! So just driving it around with penetrating oil was enough to break the bind.
P
2002 Chevy Express 1500 conversion van (Explorer SE conversion)
RIP (totaled in Feb '18): 1996 Chevy Express 1500 conversion van (Starcraft Hi-Top Conversion)
Edited by MiragePilot on 01-11-19 09:37 AM. Reason for edit: typos
454cid
Loc: West Michigan
Reg: 02-18-12
01-12-19 08:17 PM - Post#2757237
I usually use a large sledge hammer on the sidewall of the tire.
You could try hitting it from the backside, since that's the direction you wan the wheel to go.
Did you try loosing the lugs nuts enough to allow some slop and turning the steering with the weight of the van on the ground?
I would not do anything involving loose lug nuts "swerving hard".
99 K3500 RCLB
Bill K.b
Loc: upstate NY
Reg: 10-24-05
01-13-19 02:12 PM - Post#2757284
    In response to 454cid
Turned wheels, rocked back and forth, drove about 10 feet and stopped as hard as it would go, hammered on rim from behind with sledge, nothing.
I mean if I go up and down my 30 MPH street and swing it hard to the right with the lugs all on but out 1/4" that might provide the force to move it over, it's still going to be riding on the hub so I can't see anything breaking.
1988 G20 conversion
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
01-13-19 02:48 PM - Post#2757286
Have to be careful with that approach as it can snap the studs off if it comes loose.
How long of a handle is on that sledge?
I like at least a few foot long on the stubborn ones
Old School GM fan FOREVER
454cid
Loc: West Michigan
Reg: 02-18-12
01-14-19 10:39 PM - Post#2757412
  • Bill K.b Said:
I mean if I go up and down my 30 MPH street and swing it hard to the right with the lugs all on but out 1/4"...
That's asking for trouble.
99 K3500 RCLB
wreckmech
Loc: Parsippany, NJ
Reg: 10-08-02
01-15-19 07:53 AM - Post#2757440
Did you try this?
01-15-19 06:00 PM - Post#2757500
    In response to wreckmech
I’ve never had one stick that bad, but I was thinking about it and it might be worth a shot to take it out for a ride and get the brakes hot. The rotor should heat up more than the wheel, so the expansion of the metal on the rotor should help break the bind. I would not drive around with the lugs loose.
1957 Cameo Carrier
Bill K.b
Loc: upstate NY
Reg: 10-24-05
01-15-19 07:19 PM - Post#2757504
    In response to wagonman100
8 lug wheels with a big fat hub on this, same as a 1 ton. Probably some rust on the surface of the hub.
I whanged on that thing with a 10 lb sledge with like a 30 inch handle, would hit it a couple solid shots, turn the wheel, hit it again. I can see I have some slop in there somewhere, it would move everything about an inch, but the rim never budged.
It's been too expletive cold to do much since then, it actually got to 35' today and I did some interior stuff it needs. It actually drives fine despite the mismatch, so I figure if it ends up being a few hundred miles before the weather cooperates enough to go mess with it it won't hurt anything. I have a whole spare rotor I took off the other side if I need it, I only swapped that one on the off chance it was warped a bit.
This all started because at 65 it would start to shake pretty bad on the right front. I took the right side apart to see what it was; nothing was obvious, but the pads on it made quite a bit of grinding noise even after I changed the rotor, so I swapped them out and I'm thinking they were the problem. But I also found the washer under the spindle nut seemed to be a bit crooked and it actually took two more turns when I put the used donor rotor on so maybe that was part of the problem too.
... and I counted the turns because on the 3500 I had a hard time getting rotors to seat correctly the times I changed them, actually ended up driving it with one just loose enough to have some slop and it messed up the ABS sensor. Couldn't tell in the least when driving it. Figured if I counted how many to take the nut off then I'd know it was wrong if it was tight before that many back on.
1988 G20 conversion
Execution time: 0.086 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:47 AM
