Username Post: Window spring        (Topic#354798)
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
01-10-19 08:27 PM - Post#2757083
Has anyone ever tried to remove a window crank spring? I'd like to take it off to deal with the rust and for lubrication. My concern is that I might not be able to get it re-tensioned.
Attachment: window_spring.jpg (929.25 KB) 13 View(s)
Window crank spring
Scott Acton
1954 Chevy Bel Air 2-door
http://www.my54chevy.com
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
01-10-19 08:43 PM - Post#2757084
    In response to dsacton
I've never removed one, but I'm ALWAYS up to a challenge. My first inclination is to figure out how difficult or how much tension / load is in the spring and in what position there is the least amount of tension or load. Once that is determined, how easy / difficult is it to pry back off of the stop. If relatively easy to pull / push back off of the stop...half the battle is won. Looks MUCH easier than doing hood springs.
1951 Fleetline
tommy49
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
01-11-19 05:45 AM - Post#2757096
I'd pay the money and get the regulater sandblasted. Messing with that spring has written all over it!
Tommy
49 Deluxe Sport Coupe, 55 235, 700r4, Blazer rear axle, 4 wheel power disc brakes.
eplantage
Loc: Southern MN
Reg: 03-15-04
01-11-19 07:55 AM - Post#2757106
There has been some discussion on here about using a spooge tank to remove rust. It's an electrolysis process. That way you could leave the spring attached. I agree with the others that it might turn into a can of worms if you remove it which would be easier than getting it back on.
Age: 65 at the moment
1950 Chevrolet Sedan Delivery
2002 Heritage Springer FLSTSI
1930 Model A Standard Coupe
lobucrod
lobucrod
Loc: Springtown Texas
Reg: 10-01-07
01-11-19 08:28 AM - Post#2757111
    In response to eplantage
I’ve replaced them before. Grab the end of the spring with a pair of vise grips and wind the spring up over the stop then pull it out and slowly unwind it. As you start to pull it off of the stop you will know how much tension is on it. It’s manageable.
'38 Chevy Coupe Gasser 409 powered
'50 Sedan Delivery 401 Nailhead powered
'62 Buick Electra original survivor
Edited by lobucrod on 01-11-19 08:30 AM. Reason for edit: No reason given.
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
01-11-19 10:13 AM - Post#2757118
    In response to lobucrod
Thanks for lending me your experience. Where do you get a replacement spring? I was going to derust this one and try a metal bluing process, or perhaps a plating process to stop future rust. But a new part would be a lot better.
Scott Acton
50hotrod
50hotrod
Reg: 07-25-11
01-11-19 03:17 PM - Post#2757135
De-grease it and soak it is this.
https://shop.advanceautoparts.com/p/evapo-rust-eva...
1950 CHEVY 2 DOOR 327 TRI POWER FENDERWELL HEADERS HEIDT FRONT SUSPENSION 700R4 TRANS 411 REAR
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
01-11-19 10:43 PM - Post#2757171
    In response to 50hotrod
Interesting product. I will give it a shot. Sounds a lot better than hydrochloric acid.
Scott Acton
lobucrod
lobucrod
Reg: 10-01-07
01-12-19 05:50 AM - Post#2757177
I pulled one off of an extra regulator I had lying around.
01-12-19 08:38 AM - Post#2757187
There is a tremendous amount of stored energy in a window crank spring. When I worked in the glass shop, many moons ago we NEVER messed with them. Too easy to lose a finger.
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
01-12-19 11:58 AM - Post#2757198
I hear you, Robert. Last night, I made this tool to remove the spring. Went to take it out this morning...and finally came to my senses. I will live with a little rust (and both eyes). Thanks for the caution.
Cheers,
Attachment: spring_tool.jpg (716.84 KB) 12 View(s)
Spring removal tool.
Scott Acton
01-13-19 06:01 PM - Post#2757296
Good choice Scott. I've removed automotive coil springs, using a good spring compressor, but the trouble with the window spring is it is small and VERY robust. Thus it can get away from you pretty easily. With something like a suspension coil spring, it's big enough that you can get a good sized spring compressor on it so it can't get away. Maybe a holder like that would work but if it doesn't... ouch. ;-)
dsacton
dsacton
Loc: Boulder, CO
Reg: 11-01-11
01-15-19 04:29 PM - Post#2757487
I tried the Evapo-Rust product. In general, I am very pleased with its performance. It is slow acting, but very effective. Thanks for the suggestion.
Scott Acton
Execution time: 0.1 seconds.   Total Queries: 19   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:06 PM
