turfman454
Reg: 10-04-05
01-10-19 07:17 PM - Post#2757082
Anyone replaced the vent window regulator. Mine is stripped and i bought a replacement. Anything i need to be concerned with before i tear into it?
Broo102
"4th" Silver Supporting Member
Loc: Huntington Beach, CA.
Reg: 09-30-14
02-01-19 08:19 PM - Post#2758798
In response to turfman454
If the replacement is in good shape, make sure the gears are cleaned of dirt etc. then grease the gears up.
Install in reverse of removal; you can look in the chevy old car manual, if you need any other help.
Thanks!
Bru
John 3:16
32 Chev. 5 Win. Sports Coupe
47 Chev. convertible in progress |
42Special
Loc: NW
Reg: 09-24-16
02-10-19 01:29 PM - Post#2759564
When I replaced mine with NOS that I located. I drilled a small hole through the pot metal housing and squirted some light machine oil in them and worked them back and forth to loosen the hardened grease that was inside. It worked out well.
Broo102
Reg: 09-30-14
02-13-19 03:24 PM - Post#2759854
In response to 42Special
Even better!
Thanks!
Bru
John 3:16
