Username Post: vent window regulator        (Topic#354797)
turfman454
Reg: 10-04-05
01-10-19 08:17 PM - Post#2757082
Anyone replaced the vent window regulator. Mine is stripped and i bought a replacement. Anything i need to be concerned with before i tear into it?
Chevs of the 40s
Broo102
"4th" Silver Supporting Member
Broo102
Loc: Huntington Beach, CA.
Reg: 09-30-14
02-01-19 09:19 PM - Post#2758798
    In response to turfman454
If the replacement is in good shape, make sure the gears are cleaned of dirt etc. then grease the gears up.
Install in reverse of removal; you can look in the chevy old car manual, if you need any other help.
Thanks!
Bru
John 3:16
32 Chev. 5 Win. Sports Coupe
42Special
42Special
Loc: NW
Reg: 09-24-16
02-10-19 02:29 PM - Post#2759564
When I replaced mine with NOS that I located. I drilled a small hole through the pot metal housing and squirted some light machine oil in them and worked them back and forth to loosen the hardened grease that was inside. It worked out well.
Broo102
Broo102
Reg: 09-30-14
02-13-19 04:24 PM - Post#2759854
    In response to 42Special
Even better!
Thanks!
Bru
John 3:16
Chevs of the 40s
Execution time: 0.112 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:13 PM
