Username Post: speedometer gear        (Topic#354794)
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-10-19 05:36 PM - Post#2757068
I was messing with the 64 today and decided to check the speedo gear in the power glide. It's a 19 tooth gear and my speedometer is 10 MPH slow. I need a 16 tooth according to the TCI transmission websit but they don't have anything other than 19/20 tooth's. Per their sit each tooth is about 2mph taken away are added.
Does anybody know if there is even such a animal? If so could you be kind enough to post links so I can order one. I have found 17 tooth but no 16.
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Edited by Andy4639 on 01-10-19 05:37 PM. Reason for edit: No reason given.
01-10-19 06:05 PM - Post#2757074
    In response to Andy4639
There is not, and never was, a 16teeth plastic side gear. There are/were: 17, 18, 19, 20, 21, 22teeth gears.
The 17 teeth gears (GM part number 3987917-purple) are getting harder and harder to find.
The 18 teeth gears (GM part number 3987918-brown) are fairly common.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-10-19 06:15 PM - Post#2757075
Thanks,
This is what I was thinking also since all the sits I checked today offered only the 17. I guess I'll order the 17 and get as close as I can.:toast:
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
omarine
Loc: San Diego
Reg: 06-29-15
01-11-19 11:55 AM - Post#2757129
you could also get a sppedo corrector (I think it's called)
it screws into the trans, then the cable screws into the ratio corrector.
I got mine from Art Carr transmissions in Huntington Beach, CA. was like $75 I think.
they ask you for some #s - actual speed vs displayed speed at 20, 40, 60 mph if I recall correctly....
61 Impala bubbletop, 283, 2bbl Rochester, generator, points and drum brakes- daily driver
'49 Harley Davidson FL - Panhead
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-11-19 01:09 PM - Post#2757130
    In response to omarine
Yes I have been looking into one of those also. Gear Ratio Adapter to speed your Speedometer up.
I'm going to order the 17 tooth gear first and see where it ends up at and then try one.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
01-11-19 05:05 PM - Post#2757150
according to my experience,each tooth on the driven gear makes 4 -5 mph difference. you can also change the drive gear on the output shaft on the transmission.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
14 camaro (new)
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-11-19 06:56 PM - Post#2757163
    In response to 62chevy427
I hope your right because I ordered the 17 tooth tonight. If it's that much I should be right on the money!
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
64ausbelair
64ausbelair
Loc: Australia (QLD)
Reg: 10-26-06
01-11-19 09:40 PM - Post#2757170
I need to get a different gear on mine also. It reads about 73 when I’m actually doing about 63. (100 kmh here )
Less teeth increases speedo readout speed?
junky
Loc: Northeast CT
Reg: 06-27-10
01-11-19 10:14 PM - Post#2757173
    In response to 64ausbelair
From a post that I made about speedometer error correction last June.
http://www.tciauto.com/tc/speedometer-gear-c alcula... and I entered the number of teeth on the drive gear (8), the tire size P215-75-14, and that gave me tire diameter of 26.40 .. I entered all this information into the calculator, and it came back with "number of driven teeth" 20.223312268256087.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-12-19 06:09 AM - Post#2757179
    In response to junky
I have questions on this:
1. How do you decide the driven gear inside the transmission? If it's out of the car I do but not when it's in the car.
2. What does the wheel diameter have to do with it? The tire diameter yes but the wheel it's part of the overall tire measurment???
3. Tire width, again what does this have to do with it?
I don't understand.
I called them (TCI) and talked with a CS guy and he told me what tooth count I needed. Which is 16 but there isn't such animal so I'm going for the 17 and call it good I hope.
I may get a gear ratio also later if the 17 doesn't do it.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
01-12-19 06:57 AM - Post#2757184
I would expect the rear gear ratio to be a significant (the most significant back the '60s) variable.
As noted by others, tire diameter would be another. But back when the cars were designed, tire diameters (as provided by GM) were not as 'variable' as those available/used today.
The state police used to (likely still do) get their car's speedo's calibrated every so often. There may be a procedure available some where.
Pete
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-12-19 09:53 AM - Post#2757196
    In response to japete92
Pete
Yes there was a place locally that would calibrate your speedometer for you but they went out of business. Yes the size of the tires makes a more interesting challenge to get the right gear as well. Hopefully the 17 tooth gear does the trick.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
55Brodie
55Brodie
Loc: Little River, SC
Reg: 12-26-15
01-12-19 11:45 AM - Post#2757202
What you really need to know is the loaded radius of the rear tire.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-13-19 07:40 AM - Post#2757259
    In response to 55Brodie
The measurement was with the car on the ground. 25" tall tires with weight of the car but no driver. He was doing the measuring!
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
55Brodie
55Brodie
Reg: 12-26-15
01-13-19 09:55 AM - Post#2757269
If your speedometer is reading "fast", you need to ADD more teeth to the driven gear. 73 ÷ 63 = approx. 1.16. Multiply that times the number of teeth you have now to arrive at the correct gear.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-13-19 10:32 AM - Post#2757270
Dang it, I knew I should have ordered the whole set of gears!
My speedometer says 64/65 but my GPS said 55. That's close, with holding a constant 65 is hard to do. According to what you said and the old gear is 19 now so that means a 22.04 gear is needed.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
55Brodie
55Brodie
Reg: 12-26-15
01-14-19 01:45 AM - Post#2757313
I was responding to 64ausbelair, but yes, the math says 22 teeth for you.
Edited by 55Brodie on 01-14-19 01:50 AM. Reason for edit: No reason given.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-19-19 08:53 AM - Post#2757724
I ordered a 22 tooth this morning.
Been busy working on the 67 ramp truck.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Execution time: 0.098 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:55 AM
