Username Post: speedometer gear        (Topic#354794)
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-10-19 06:36 PM - Post#2757068
I was messing with the 64 today and decided to check the speedo gear in the power glide. It's a 19 tooth gear and my speedometer is 10 MPH slow. I need a 16 tooth according to the TCI transmission websit but they don't have anything other than 19/20 tooth's. Per their sit each tooth is about 2mph taken away are added.
Does anybody know if there is even such a animal? If so could you be kind enough to post links so I can order one. I have found 17 tooth but no 16.
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Edited by Andy4639 on 01-10-19 06:37 PM. Reason for edit: No reason given.
01-10-19 07:05 PM - Post#2757074
    In response to Andy4639
There is not, and never was, a 16teeth plastic side gear. There are/were: 17, 18, 19, 20, 21, 22teeth gears.
The 17 teeth gears (GM part number 3987917-purple) are getting harder and harder to find.
The 18 teeth gears (GM part number 3987918-brown) are fairly common.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-10-19 07:15 PM - Post#2757075
Thanks,
This is what I was thinking also since all the sits I checked today offered only the 17. I guess I'll order the 17 and get as close as I can.:toast:
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
omarine
Loc: San Diego
Reg: 06-29-15
01-11-19 12:55 PM - Post#2757129
you could also get a sppedo corrector (I think it's called)
it screws into the trans, then the cable screws into the ratio corrector.
I got mine from Art Carr transmissions in Huntington Beach, CA. was like $75 I think.
they ask you for some #s - actual speed vs displayed speed at 20, 40, 60 mph if I recall correctly....
61 Impala bubbletop, 283, 2bbl Rochester, generator, points and drum brakes- daily driver
'49 Harley Davidson FL - Panhead
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-11-19 02:09 PM - Post#2757130
    In response to omarine
Yes I have been looking into one of those also. Gear Ratio Adapter to speed your Speedometer up.
I'm going to order the 17 tooth gear first and see where it ends up at and then try one.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
62chevy427
62chevy427
Loc: laurens sc
Reg: 04-13-06
01-11-19 06:05 PM - Post#2757150
according to my experience,each tooth on the driven gear makes 4 -5 mph difference. you can also change the drive gear on the output shaft on the transmission.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
15 chevy equinox
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-11-19 07:56 PM - Post#2757163
    In response to 62chevy427
I hope your right because I ordered the 17 tooth tonight. If it's that much I should be right on the money!
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
64ausbelair
64ausbelair
Loc: Australia (QLD)
Reg: 10-26-06
01-11-19 10:40 PM - Post#2757170
I need to get a different gear on mine also. It reads about 73 when I’m actually doing about 63. (100 kmh here )
Less teeth increases speedo readout speed?
junky
Loc: Northeast CT
Reg: 06-27-10
01-11-19 11:14 PM - Post#2757173
    In response to 64ausbelair
From a post that I made about speedometer error correction last June.
http://www.tciauto.com/tc/speedometer-gear-c alcula... and I entered the number of teeth on the drive gear (8), the tire size P215-75-14, and that gave me tire diameter of 26.40 .. I entered all this information into the calculator, and it came back with "number of driven teeth" 20.223312268256087.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-12-19 07:09 AM - Post#2757179
    In response to junky
I have questions on this:
1. How do you decide the driven gear inside the transmission? If it's out of the car I do but not when it's in the car.
2. What does the wheel diameter have to do with it? The tire diameter yes but the wheel it's part of the overall tire measurment???
3. Tire width, again what does this have to do with it?
I don't understand.
I called them (TCI) and talked with a CS guy and he told me what tooth count I needed. Which is 16 but there isn't such animal so I'm going for the 17 and call it good I hope.
I may get a gear ratio also later if the 17 doesn't do it.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
japete92
japete92
Loc: No. Virginia
Reg: 01-18-13
01-12-19 07:57 AM - Post#2757184
I would expect the rear gear ratio to be a significant (the most significant back the '60s) variable.
As noted by others, tire diameter would be another. But back when the cars were designed, tire diameters (as provided by GM) were not as 'variable' as those available/used today.
The state police used to (likely still do) get their car's speedo's calibrated every so often. There may be a procedure available some where.
Pete
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-12-19 10:53 AM - Post#2757196
    In response to japete92
Pete
Yes there was a place locally that would calibrate your speedometer for you but they went out of business. Yes the size of the tires makes a more interesting challenge to get the right gear as well. Hopefully the 17 tooth gear does the trick.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
55Brodie
55Brodie
Loc: Little River, SC
Reg: 12-26-15
01-12-19 12:45 PM - Post#2757202
What you really need to know is the loaded radius of the rear tire.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-13-19 08:40 AM - Post#2757259
    In response to 55Brodie
The measurement was with the car on the ground. 25" tall tires with weight of the car but no driver. He was doing the measuring!
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
55Brodie
55Brodie
Reg: 12-26-15
01-13-19 10:55 AM - Post#2757269
If your speedometer is reading "fast", you need to ADD more teeth to the driven gear. 73 ÷ 63 = approx. 1.16. Multiply that times the number of teeth you have now to arrive at the correct gear.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-13-19 11:32 AM - Post#2757270
Dang it, I knew I should have ordered the whole set of gears!
My speedometer says 64/65 but my GPS said 55. That's close, with holding a constant 65 is hard to do. According to what you said and the old gear is 19 now so that means a 22.04 gear is needed.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
55Brodie
55Brodie
Reg: 12-26-15
01-14-19 02:45 AM - Post#2757313
I was responding to 64ausbelair, but yes, the math says 22 teeth for you.
Edited by 55Brodie on 01-14-19 02:50 AM. Reason for edit: No reason given.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-19-19 09:53 AM - Post#2757724
I ordered a 22 tooth this morning.
Been busy working on the 67 ramp truck.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-22-19 04:06 PM - Post#2757969
Just got done with installing the 22 tooth gear and test driving it. It's dead on with my GPS now.
Thanks to everyone.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
junky
Loc: Northeast CT
Reg: 06-27-10
01-22-19 10:15 PM - Post#2757981
Is it exact at all speeds? Mine is off at the lower speeds, and exact at 60 MPH.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-23-19 04:44 AM - Post#2757989
It maybe a bit off at slower speeds but it's hard to tell. At 45 MPH and above it's pretty much dead on. I'm good with it and want bother with GPS anymore. 1-2 MPH off is hard to tell since the GPS reacts different than the speedometer. That little bit want get me a ticket though.:toast:
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
kingkreeton
kingkreeton
Loc: Houston TX
Reg: 04-15-11
01-23-19 05:58 PM - Post#2758049
Good to hear. Was it hard to install?
Shane
64 Impala SS:
Chevy Performance 350HO
4 Speed Muncie
Proud member of Big Blue Nation, University of Kentucky Basketball. "Go Big Blue"
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-24-19 07:15 AM - Post#2758101
    In response to kingkreeton
Nope not at all. Went right in. Took maybe 30 minutes to jack it up put jack stand under it and slide under it in the garage and replace it.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
junky
Loc: Northeast CT
Reg: 06-27-10
01-24-19 07:40 AM - Post#2758103
Easy to do... once you are under the car, unscrew the speedometer cable from the speedometer adapter, remove the 3/8" bolt from the transmission that holds the adapter into the transmission, and pull out the adapter. Remove gear and install new gear. Reversed the removal procedure, and you are done. Very little to no fluid loss, which makes the job even easier.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-24-19 02:39 PM - Post#2758131
The bolt holding the bullet in mine was 7/16" head. Other than that as Junky said no fluid lose at all. I jack the car up in the drivers side wheel area and place a jack stand right behind the tire under the frame in the flat. No trans fluid at all will come out at that angle.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
sanee64
Loc: atlanta ga
Reg: 04-05-18
03-03-19 03:34 PM - Post#2761208
Hey guys
gonna thread jack this but is there a way to get a new rubber seal? mine leaks tranny fluid or do i have to buy a whole new speedometer cable?
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
03-03-19 03:50 PM - Post#2761209
    In response to sanee64
  • sanee64 Said:
Hey guys
Which one, The seal inside the cable housing part are the bullet o-ring.
On the cable I used a o ring I had that looked close enough to fit. I put in and tightened down and it has leaked any. As far as the bullet I have a couple of the o-rings.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
sanee64
Loc: atlanta ga
Reg: 04-05-18
03-03-19 04:04 PM - Post#2761212
im not sure if im gonna explain it well but i guess it looks like a bullet. its the part thats screwed in/pushed in to the tranny. Its the o-ring outside (im guessing) thats old and leaking. Where did you get that o-ring?
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
03-03-19 04:08 PM - Post#2761213
here is what the housing looks like that holds the plastic gear. It has 2 rubber seals one outside and one inside. The entire housing comes out of the transmission after removing the hex bolt and washer.
https://www.classictransmissionsoluti ons.com/1955-...
The speedometer plastic gear will look like this(this picture has a number of the different plastic gears) "that can be used" -the teeth numbers change by color of the gear to change the speedometer calibration:
https://www.ebay.com/itm/18-19-20-21-22-Te eth-Spee...
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
62 Imp CV SS 327/300HP 700R4
62 ImpHT SS 409/482 stroker 4 spd
62 Imp SS 409 - 5 spd Convertible under frameoff
Web http://paulstensland.com/
Execution time: 0.088 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:25 PM
