Username Post: Door lock pulls        (Topic#354789)
PLS
PLS
Loc: Smyrna, Georgia
Reg: 06-07-12
01-10-19 01:05 PM - Post#2757044
I found the original door lock pulls for my ’60 which are black and when I started to clean one the black began to come off and reveal the car body color, turquoise.(they look bluish in the pictures) After I got it as clean as I could, I could see that the first third from the small end was a different shade probably because that part was never exposed to the sun indicating that the other two thirds was exposed. They have been off the car since mid-70’s and I can’t understand why they just turned black, whatever it was, just laying around in a box for 40+ years. Did the pulls come in the color of the car? Lamar
Attachment: IMG_6041_-_Copy.jpg (144.03 KB) 11 View(s)
Attachment: IMG_6045_-_Copy.JPG (141.32 KB) 12 View(s)
Jens
58-60 Subject Matter Expert - "11th Year" Silver Supporting Member
Jens
Loc: Iowa.
Reg: 04-21-02
01-10-19 04:40 PM - Post#2757061
    In response to PLS
Yes they came in many molded plastic colors. You can clean them with acetone and an old tooth brush and paint them with plastic paint or just use a base coat finish. Here's some originals.
Attachment: IMG_2072.jpg (1.12 MB) 10 View(s)
PLS
PLS
Reg: 06-07-12
01-10-19 05:44 PM - Post#2757063
    In response to Jens
Thanks Jens, for the acetone tip, they cleaned up pretty good and I will just use them the way they are. The picture still shows it bluish. Lamar
Attachment: IMG_6047.jpg (109.5 KB) 11 View(s)
stevelegel
stevelegel
Loc: Detroit MI
Reg: 09-27-09
01-12-19 02:32 PM - Post#2757209
    In response to PLS
yes...mine were green under the grime!!
Well done.
Execution time: 0.084 seconds.   Total Queries: 19   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:39 AM
