Username Post: No Oil Pressure        (Topic#354784)
APIA
Reg: 11-13-07
01-10-19 07:59 AM - Post#2757023
I have a 02 Silverado short bed, short cab, had a reman installed 36K miles ago. Parked the truck, a few minutes later restarted only to see no oil pressure on the gage accompanied by a check oil pressure light. Had the trucked towed to the dealer that installed the engine and am told the oil pressure sensor is fine and after closer inspection found metal shavings in the pan. The engine is under warranty and they are planning on fixing it, up until the other day the engine ran flawless and did not use a drop of oil. Thoughts ?
Thanks in advance...
01-10-19 08:15 AM - Post#2757025
    In response to APIA
Hmm, until it's apart and inspected, any thing else is a guess.
APIA
Reg: 11-13-07
01-11-19 09:54 AM - Post#2757117
Just got the word on my engine, cam, lifters and oil pump, pump failed... I asked about the main and rod bearings and was told everything was fine, I am not a novice as I build airplane engines, does this seem correct or am I being a worry wart....
Bill K.b
Loc: upstate NY
Reg: 10-24-05
01-11-19 02:25 PM - Post#2757132
    In response to APIA
It's possible, if it wasn't run long. I would be concerned that metal shavings are all through the motor, though.
Those who can, do. Those who can't, criticize it on the internet.
Driving 2002 Express 2500
2002 Express 2500 extended
1988 G20 conversion
1993 GMC 3500 dually
Plus cars for swap and sale
& yes, I once tried a frame swap on a 51 Chevy.
george88gta
george88gta
Loc: new york
Reg: 04-23-03
01-11-19 04:15 PM - Post#2757138
    In response to Bill K.b
If its still possible, I would ask to inspect the crank and bearings and the cam bearings. You can see any damage with the naked eye, ( scratches, etc.). If its reassembled, then you have to go with their report.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
01-11-19 07:59 PM - Post#2757164
    In response to george88gta
I agree. I would be leary of that.
Something caused the failure and whatever caused it may reoccur.
Best of luck to you
Old School GM fan FOREVER
Execution time: 0.091 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:58 PM
