Username Post: What's the best choice of rear end for 51 2 door hardtop Bel Air        (Topic#354771)
herbieraye51
herbieraye51
Loc: Delano Tennessee
Reg: 12-18-14
01-09-19 09:07 AM - Post#2756955
I have 1951 Chevy Belair 2 door hardtop and I've had it for about 30 years I had a 307 Powerglide transmission in it and then pulled that out now I have 365 horse 327 ready to install it with a R4 Transmission, the rear end that I first installed in it was out of the 72 Chevelle, I had to make the mounting pads for the rear end what, I'd like to do is install a rear end out of a about a 84 to a 88 Chevy blazer with disk brakes front and rear I'm in installing the factory ride height Springs in the rear from posies can anyone recommend what would be my best choice on the rear end I talked with Tommy 49 but I'd like a little more knowledge about what years would be the best thank you guys looking forward to hearing from you all and your opinions thanks so much Herbieraye51
Chevs of the 40s
cbmkr56
cbmkr56
Loc: Basehor Ks
Reg: 02-11-13
01-09-19 12:51 PM - Post#2756966
    In response to herbieraye51
10 bolt from a 67-69 camaro 60" hub to hub or one from a 68-74 nova 60 1/4" hub to hub gm metric disc brake calipers.
S10 disc rears have a clearance issue with the calipers to the frame.
01-09-19 03:06 PM - Post#2756975
    In response to cbmkr56
77 Camaro in my 51 Belair, just repositioned the pads, done.
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
01-10-19 04:38 AM - Post#2757010
Probably the easiest, and most direct fit, is the 55-57 Chevrolet rear end. All it takes is re-drilling the locator pin hole 1-1/2 inch forward, and 1/2 inch inward. Those rear ends are starting to getting somewhat hard to find, and can bring $$$$$. And there are many different gear ratios available for them, and new aftermarket Positractions are still available. It's the rear-end we used in the 51 Bus Coupe, and what I'd use again. I am Butch/56sedandelivery.
Edited by 56sedandelivery on 01-10-19 02:07 PM. Reason for edit: No reason given.
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
01-10-19 05:13 AM - Post#2757012
The rear end in my 53 Sport Coupe is a 1970 Nova. It fits well and disc brake kits are readily available for this rear. Mine is converted to front and rear disc brakes along with Posies rear springs.
Attachment: Newport_001.JPG (578.18 KB) 13 View(s)
Vern
1953 Chevy Belair Sport Coupe - 355 Blueprint Engine, 700-R4, Vintage Air, EZ Wire, Ididit column, Cruise/Tilt, 59 Vette Steering Wheel, 4-Wheel Disc Brakes, Posies Springs, Coker Radials, Nova 10-bolt, Mustang II front, Continental Kit
40grit
40grit
Loc: Chattanooga, Tn
Reg: 07-08-13
01-10-19 07:42 AM - Post#2757018
Scroll down this page and you will come to a list of rear end widths. There are errors on it but by and large it is pretty good.
http://www.crankshaftcoalition.com/wiki/Wheelbase,...
It is getting pretty difficult to find one of the popular rears from the 50's or 60's that isn't worn out. I used a 9" Ford (Lincoln) out of a 79 Versaille. It is pretty narrow but allows me to run a wider wheel.
The 8.8 Ford rears have an offset Pinion which makes them relatively easy to narrow since you can shorten one side and center the driveshaft.
One more thing. Before you spend money on a rear end consider the gear ratio. Most of the new ratios are built for overdrive rear ends and will not be good on the highway if you don't have OD.
Just Slightly Abrasive
DanD1950
DanD1950
Loc: London Ont. Canada
Reg: 10-16-11
01-10-19 08:28 AM - Post#2757027
    In response to 40grit
In my 50 Deluxe I put a late 1980's S Blazer 4X4 rear end in it. Cut the perches off of both the original and the replacement diffs; welded the original perches to the replacement. No drilling required for the offset spring pins.
The install went relatively well. I loosely clamped the diff to the springs. That was to allow me to position the diff left to right and be able to rotate it; when setting the pinion angle. Tighten everything up and road test; checking for drive line vibration. When all was well; weld the perches in that position.
The S blazer diff came with a 3:42 gear; which works very well with the 4 speed OD transmission (4L60E).
At 60 mph, engine RPM is approx 1900; using stock sized tires.
Dan
50 Styleline Deluxe, 2 Door Sedan, Was a 216cu", Three Speed Manual. She now has a 4.8Lt V8 LR4 injected engine, 4L60E 4 speed automatic, 10 bolt diff 342 gear with an Eaton C80 Locker
Bill K.b
Loc: upstate NY
Reg: 10-24-05
01-11-19 08:19 AM - Post#2757109
    In response to DanD1950
A second-gen Camaro/Firebird should bolt right in with the only change drilling a new hole for the locator pin, or have some lowering blocks made that compensate.
That's what I did with the '50 I had, I think it took me a couple hours to change it over.
If you go with an aftermarket spring it's even easier.
This rear is a tad wider than stock so it limits tire with to an extent.
The S10/Blazer 4x4 rearend is supposed to fit the same way. 1970s Nova may also work.
Those who can, do. Those who can't, criticize it on the internet.
Driving 2002 Express 2500
2002 Express 2500 extended
1988 G20 conversion
1993 GMC 3500 dually
Plus cars for swap and sale
& yes, I once tried a frame swap on a 51 Chevy.
drew1987
drew1987
Loc: Rochester, New York
Reg: 02-23-14
01-13-19 07:28 AM - Post#2757253
    In response to Bill K.b
I've been happy with my 57 rear, known many who've been please with a Camaro/Nova, and s10 is fine if you aren't going to be quite as aggressive. Today's small pickups have opened the door to more options, there are Asian cars (kia Sedona, TOyota 4-runner/Tacoma, Nissan exterra, pathfinder, small pickup) I didnt measure any of those but they'd easy to fine, are all narrow, and some might even have chevy bolt pattern.
Circling back, my 57 (1955-162) full size has been lovely
Andrew D. Carapella (Drew)
'50 Deluxe 4dr v8 auto
Member:
Rochester Street Rods - Est. 1970
http://www.rochesterstreetrods.org
CrossMembers Car Club - Hebrews 12:2
http://www.crossmemberscc.com
drew1987
drew1987
Reg: 02-23-14
01-13-19 07:31 AM - Post#2757254
    In response to drew1987
additionally, I was questioned/flogged for taking the time to move the spring perches on mine when I built my car, but without doing so, there is about 40% reduction of surface contact and therefor I felt it was worth my time. This is a side-to-side movement, you WILL need a new hole forward/rearward becuase the pin on the stock springs isn't centered. I used aftermarket springs so this didnt matter in my case
Member:
01-13-19 07:39 PM - Post#2757305
I cannot say what is the BEST rearend for converting a 49-54 to an open driveline.
But the EASIEST is a 55-57 Chevy rearend.
Use the ENTIRE 55-57 Chevy rear -------------- including brake backing plates/brakes (that is, if drum brakes are retained).
To install a 55-57 axle housing onto 49-54 leaf springs, drill a new hole in the 55-57 spring pads that is 1 1/2in FORWARD and 1/2in INBOARD of the existing hole. Bolt it on. Disconnect the 49-54 em brake cables from the 49-54 brake backing plates and connect them to the 55-57 backing plates. It will also be necessary to use the 55-57 shock mount plates. I have air shocks for a 55-57 Chevy on the rear of the 51. Been there for 40+yrs.
Chevs of the 40s
Execution time: 0.092 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:48 PM
